    SketchyPhysics - How to make a strong Winch Cable ?
    2 Posts 1 Posters 2.0k Views 1 Watching
    • kraftwerkK Offline
      kraftwerk
      Hello
      I'm trying to build a winch cable. With the SU 8 and SP 3.2 (or is 3.1?)
      After searching http://sketchucation.com/forums/viewtopic.php?f=61&t=24741 (thanks to hpnisse !) and more, I put a motor pulley and a upper pulley.
      And i'm using the script above to make rope / cable:
      ontouch{|t,s,p|
      connect(t,"ball") if frame==0
      Works fine if the Density of big sphere keeped in 0.2 g/cm3.
      But the rope / cable is broken when the Density is changed to the steel density of 7.5 g/cm3
      The same happens if I draw an object of greater volume in replacing the large sphere.
      So, in this momment, I can't to simulate a real winch or elevator.
      How can I feed sketchyphysics with data type as shear load, maximum load traction ...?
      What can I do avoid a broken rope / cable?
        kraftwerk
        this is the file:
        Doubt - Winch Cable.skp
