    Make OSX WebDialog alert of script errors?
    6 Posts 4 Posters 299 Views 4 Watching
    • thomthomT
      I find that when an error happen in an OSX WebDialog the messages are silently eaten. Is there a way to make it pop up an alert, like under Windows IE?
      • thomthomT
        No window.onerror for Safari it appears. Googling and checking stackoverflow.
        • A
          Aerilius
          In internet explorer we can redirect popup errors to the Ruby Console, so I guess Safari would also trigger the onerror handler?
          window.onerror = function(errorMsg, url, lineNumber){
            Dialog.callRuby("puts", errorMsg, url, lineNumber); // or whatever callback...
            return true; // This prevents tells the browser the error needs no further handling (no popup).
          • thomthomT
            Maybe this can work: http://extechops.net/2011/07/04/generic-onerror/
            • D
              driven
              error alerts like this work
              wwhdlg = UI;;WebDialog.new("wot_works_here", true, "wwh", 739, 641, 50, 50, true);
               wwhdlg.set_url "http://www.eborcom.com/webmaker/tutorials/rhoque/ex2_5.html"
               wwhdlg.show_modal
               wwhdlg.navigation_buttons_enabled=true
              • Dan RathbunD
                Dan Rathbun
                The MSDN page says there are no standards that apply to onerror (its IE only.)
                You could it on both the document and window objects just to be sure.
                If Safari is DOM Level 3, then you may need to use:
                %(#8000BF)[window.addEventListener("error",*fHandlerName*,*bCapture*)]
                [window.addEventListener](http://msdn.microsoft.com/en-us/library/ff975245(v)
                DOM Level 3: Error
                Example:
                http://msdn.microsoft.com/en-us/library/hh772306(v=vs.85).aspx
                Or you could %(#8000BF)[catch] the errors with JS:
                [url=http://msdn.microsoft.com/en-us/library/4yahc5d8(v=vs.85).aspx:3cyk4r6q]try ... catch ... finally[/url:3cyk4r6q]
                [url=http://msdn.microsoft.com/en-us/library/85fscz6h(v=vs.85).aspx:3cyk4r6q]throw[/url:3cyk4r6q]
                [url=http://msdn.microsoft.com/en-us/library/dww52sbt(v=vs.85).aspx:3cyk4r6q]Error object[/url:3cyk4r6q]
                I'm not here much anymore.
