    [plugin/code] get global coordinates, the brute force way
    4 Posts 4 Posters 1.3k Views 4 Watching
    • liquid98L Offline
      liquid98
      Hello guys,
      This script gives you all real world coordinates of vertices in ((deeply)-nested)entities in the active model.
      The script is largely based on a script named 'SketchUp to DXF STL Converter'. For more details please see the attachment.
      It's brute force, so I'm curious for more elegant solutions....
      Liquid
      get_global coordinates.rb
      Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
        shannonnovus
        I'd also very much like a way to access the global coordinates of points within groups without needing to reference the nesting parents transformation. The brute force method works, but has anyone found a better way to do this yet?
        • tt_suT Offline
          tt_su
          Can you describe your scenario in more detail? Got a sample code snippet?
          Why don't you want to use the parent transformation?
          If it's within an open group or component you can use model.edit_transform, but otherwise you have to somehow collect the parent transformations.
            Anton_S
            Here's a piece of code I've written for the new project to get stuff from groups/components. Maybe you'll find it useful:
            #   Anton Synytsia
            #   anton.synytsia@gmail.com
            module MSPhysics
              module Group
                # @!visibility private
                VALID_TYPES = [Sketchup;;Group, Sketchup;;ComponentInstance].freeze
                INVALID_TYPE = 'The specified entity is not a group or a component!'.freeze
                module_function
                # Get entities of a group/component/definition.
                # @param [Sketchup;;Group, Sketchup;;ComponentInstance, Sketchup;;ComponentDefinition] ent
                # @return [Sketchup;;Entities, NilClass]
                # @since 1.0.0
                def get_entities(ent)
                  case ent
                  when Sketchup;;Group, Sketchup;;ComponentDefinition
                    ent.entities
                  when Sketchup;;ComponentInstance
                    ent.definition.entities
                  else
                    nil
                # Get all edges of a group/component.
                # @param [Sketchup;;Group, Sketchup;;ComponentInstance] ent
                # @param [Boolean] recursive Whether to include all the child groups and
                #   components.
                # @param [Boolean] transform Whether to give points in global coordinates.
                # @return [Array<Array<Geom;;Point3d>>] An array of edges. Each edge
                #   represents an array of two points.
                # @since 1.0.0
                def get_edges(ent, recursive = true, transform = true)
                  unless VALID_TYPES.include?(ent.class)
                    raise INVALID_TYPE
                  edges = []
                  get_entities(ent).each { |e|
                    if VALID_TYPES.include?(e.class) and (recursive == true)
                      edges.push *get_edges(e, true, true)
                      next
                    next unless e.is_a?(Sketchup;;Edge)
                    edge = []
                    e.vertices.each { |v| edge.push v.position }
                    edges.push edge
                  if transform == true
                    edges.each { |edge|
                      edge.each { |pt| pt.transform!(ent.transformation) }
                  edges
                # Get vertices from all edges of a group/component.
                #   components.
                # @return [Array<Geom;;Point3d>] An array of points.
                # @since 1.0.0
                def get_vertices_from_edges(ent, recursive = true, transform = true)
                    raise INVALID_TYPE
                  pts = []
                  verts = []
                      pts.push *get_vertices_from_edges(e, true, true)
                      next
                      verts.push(v) unless verts.include?(v)
                  verts.each { |v| pts.push v.position }
                    pts.each { |pt| pt.transform!(ent.transformation) }
                  pts
                # Get all faces of a group/component.
                #   components.
                # @return [Array<Array<Geom;;Point3d>>] An array of faces. Each face
                #   represents an array of points.
                # @since 1.0.0
                def get_faces(ent, recursive = true, transform = true)
                    raise INVALID_TYPE
                  faces = []
                      faces.push *get_faces(e, true, true)
                      next
                    next unless e.is_a?(Sketchup;;Face)
                    face = []
                    e.vertices.each { |v| face.push v.position }
                    faces.push face
                    faces.each { |face|
                      face.each { |pt| pt.transform!(ent.transformation) }
                  faces
                # Get vertices from all faces of a group/component.
                #   components.
                # @since 1.0.0
                def get_vertices_from_faces(ent, recursive = true, transform = true)
                    raise INVALID_TYPE
                  pts = []
                  verts = []
                      pts.push *get_vertices_from_faces(e, true, true)
                      next
                  pts
                # Get all construction points and lines of a group/component.
                #   components.
                # @since 1.0.0
                def get_construction(ent, recursive = true, transform = true)
                    raise INVALID_TYPE
                  pts = []
                      pts.push *get_construction(e, true, true)
                      next
                    if e.is_a?(Sketchup;;ConstructionPoint)
                      pts.push e.position
                    elsif e.is_a?(Sketchup;;ConstructionLine)
                      pts.push(e.start) unless e.start.nil?
                      pts.push(e.end) unless e.end.nil?
                  pts
              end # module Group
            end # module MSPhysics
