[plugin/code] get global coordinates, the brute force way
Hello guys,
This script gives you all real world coordinates of vertices in ((deeply)-nested)entities in the active model.
The script is largely based on a script named 'SketchUp to DXF STL Converter'. For more details please see the attachment.It's brute force, so I'm curious for more elegant solutions....
Liquid
I'd also very much like a way to access the global coordinates of points within groups without needing to reference the nesting parents transformation. The brute force method works, but has anyone found a better way to do this yet?
Can you describe your scenario in more detail? Got a sample code snippet?
Why don't you want to use the parent transformation?If it's within an open group or component you can use model.edit_transform, but otherwise you have to somehow collect the parent transformations.
Here's a piece of code I've written for the new project to get stuff from groups/components. Maybe you'll find it useful:
# ------------------------------------------------------------------------------ # # Anton Synytsia # anton.synytsia@gmail.com # # ------------------------------------------------------------------------------ module MSPhysics module Group # @!visibility private VALID_TYPES = [Sketchup;;Group, Sketchup;;ComponentInstance].freeze # @!visibility private INVALID_TYPE = 'The specified entity is not a group or a component!'.freeze module_function # Get entities of a group/component/definition. # @param [Sketchup;;Group, Sketchup;;ComponentInstance, Sketchup;;ComponentDefinition] ent # @return [Sketchup;;Entities, NilClass] # @since 1.0.0 def get_entities(ent) case ent when Sketchup;;Group, Sketchup;;ComponentDefinition ent.entities when Sketchup;;ComponentInstance ent.definition.entities else nil end end # Get all edges of a group/component. # @param [Sketchup;;Group, Sketchup;;ComponentInstance] ent # @param [Boolean] recursive Whether to include all the child groups and # components. # @param [Boolean] transform Whether to give points in global coordinates. # @return [Array<Array<Geom;;Point3d>>] An array of edges. Each edge # represents an array of two points. # @since 1.0.0 def get_edges(ent, recursive = true, transform = true) unless VALID_TYPES.include?(ent.class) raise INVALID_TYPE end edges = [] get_entities(ent).each { |e| if VALID_TYPES.include?(e.class) and (recursive == true) edges.push *get_edges(e, true, true) next end next unless e.is_a?(Sketchup;;Edge) edge = [] e.vertices.each { |v| edge.push v.position } edges.push edge } if transform == true edges.each { |edge| edge.each { |pt| pt.transform!(ent.transformation) } } end edges end # Get vertices from all edges of a group/component. # @param [Sketchup;;Group, Sketchup;;ComponentInstance] ent # @param [Boolean] recursive Whether to include all the child groups and # components. # @param [Boolean] transform Whether to give points in global coordinates. # @return [Array<Geom;;Point3d>] An array of points. # @since 1.0.0 def get_vertices_from_edges(ent, recursive = true, transform = true) unless VALID_TYPES.include?(ent.class) raise INVALID_TYPE end pts = [] verts = [] get_entities(ent).each { |e| if VALID_TYPES.include?(e.class) and (recursive == true) pts.push *get_vertices_from_edges(e, true, true) next end next unless e.is_a?(Sketchup;;Edge) e.vertices.each { |v| verts.push(v) unless verts.include?(v) } } verts.each { |v| pts.push v.position } if transform == true pts.each { |pt| pt.transform!(ent.transformation) } end pts end # Get all faces of a group/component. # @param [Sketchup;;Group, Sketchup;;ComponentInstance] ent # @param [Boolean] recursive Whether to include all the child groups and # components. # @param [Boolean] transform Whether to give points in global coordinates. # @return [Array<Array<Geom;;Point3d>>] An array of faces. Each face # represents an array of points. # @since 1.0.0 def get_faces(ent, recursive = true, transform = true) unless VALID_TYPES.include?(ent.class) raise INVALID_TYPE end faces = [] get_entities(ent).each { |e| if VALID_TYPES.include?(e.class) and (recursive == true) faces.push *get_faces(e, true, true) next end next unless e.is_a?(Sketchup;;Face) face = [] e.vertices.each { |v| face.push v.position } faces.push face } if transform == true faces.each { |face| face.each { |pt| pt.transform!(ent.transformation) } } end faces end # Get vertices from all faces of a group/component. # @param [Sketchup;;Group, Sketchup;;ComponentInstance] ent # @param [Boolean] recursive Whether to include all the child groups and # components. # @param [Boolean] transform Whether to give points in global coordinates. # @return [Array<Geom;;Point3d>] An array of points. # @since 1.0.0 def get_vertices_from_faces(ent, recursive = true, transform = true) unless VALID_TYPES.include?(ent.class) raise INVALID_TYPE end pts = [] verts = [] get_entities(ent).each { |e| if VALID_TYPES.include?(e.class) and (recursive == true) pts.push *get_vertices_from_faces(e, true, true) next end next unless e.is_a?(Sketchup;;Face) e.vertices.each { |v| verts.push(v) unless verts.include?(v) } } verts.each { |v| pts.push v.position } if transform == true pts.each { |pt| pt.transform!(ent.transformation) } end pts end # Get all construction points and lines of a group/component. # @param [Sketchup;;Group, Sketchup;;ComponentInstance] ent # @param [Boolean] recursive Whether to include all the child groups and # components. # @param [Boolean] transform Whether to give points in global coordinates. # @return [Array<Geom;;Point3d>] An array of points. # @since 1.0.0 def get_construction(ent, recursive = true, transform = true) unless VALID_TYPES.include?(ent.class) raise INVALID_TYPE end pts = [] get_entities(ent).each { |e| if VALID_TYPES.include?(e.class) and (recursive == true) pts.push *get_construction(e, true, true) next end if e.is_a?(Sketchup;;ConstructionPoint) pts.push e.position elsif e.is_a?(Sketchup;;ConstructionLine) pts.push(e.start) unless e.start.nil? pts.push(e.end) unless e.end.nil? end } if transform == true pts.each { |pt| pt.transform!(ent.transformation) } end pts end end # module Group end # module MSPhysics
