    Web Dialog: Trouble passing string from ruby to javascript
    4 Posts 2 Posters 1.5k Views 2 Watching
      sachi
      “var” is a String type ruby variable. I can’t pass characters to web dialog box though the ruby variable “var”. This works fine when the string contains integers. (eg: var=”12”).I can’t figure out why?
      I like to know about your suggestions about this problem.
      Ruby Code
      ` var= "a"
      dialog = UI::WebDialog.new("Building details", true, "", 410, 875, 1030, 0, true)
      dialog.add_action_callback("pass_data"){|dialog,htmlpage|
      java = "set_id("+var+")"
      dialog.execute_script(java)
      %(#0000BF)[Html and javascript
      <html>
      <script>
      function callRuby(htmlpage) {
      query = 'skp:pass_data@' + htmlpage;
      window.location.href = query;}
      function set_id(var){
      var message = "ID = " +var+ " ";
      document.getElementById('output').innerHTML = message;}
      </script>
      <body>
      <h3 id="output">Object ID </h3>
      <input type="button" onclick="callRuby('pull_selection_count')" value="Refresh">
      </body>
      </html>]
        You must ensure to compile a proper JavaScript string - check the string you send to execute_script.
        From your example:
        <span class="syntaxdefault"></span><span class="syntaxkeyword">var=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"a"<br /></span><span class="syntaxdefault">java </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"set_id("</span><span class="syntaxkeyword">+var+</span><span class="syntaxstring">")"<br /></span><span class="syntaxdefault">dialog</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">execute_script</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">java</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"></span>
        The string java you send to the WebDialog is compiled to:
        set_id(a)
        You see your problem now? You're asking of a JS variable a instead of a string "a".
        That's why a number works:
        <span class="syntaxdefault"></span><span class="syntaxkeyword">var=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"5"<br /></span><span class="syntaxdefault">java </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"set_id("</span><span class="syntaxkeyword">+var+</span><span class="syntaxstring">")"<br /></span><span class="syntaxdefault">dialog</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">execute_script</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">java</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"></span>
        This compiles to:
        set_id(5) - which is valid.
        Because the string you send to the webdialog is a javascript source string you must ensure the correct quotes are there.
        A quick way to ensure strings are properly escaped is using the .inspect method.
        <span class="syntaxdefault"></span><span class="syntaxkeyword">var=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"a"<br /></span><span class="syntaxdefault">java </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"set_id(#{var.inspect})"<br /></span><span class="syntaxdefault">dialog</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">execute_script</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">java</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"></span>
        This will translate to set_id("a")
        Further more, if you have single and double quotes that needs to be there, they will be properly escaped as well:
        <span class="syntaxdefault"></span><span class="syntaxkeyword">var=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">%{</span><span class="syntaxdefault">A string with </span><span class="syntaxstring">"double"</span><span class="syntaxdefault"> and </span><span class="syntaxstring">'single'</span><span class="syntaxdefault"> quotes</span><span class="syntaxkeyword">.}<br /></span><span class="syntaxdefault">java </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"set_id(#{var.inspect})"<br /></span><span class="syntaxdefault">dialog</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">execute_script</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">java</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"></span>
        This will translate into: set_id("A string with \"double\" and 'single' quotes.")
          Note, I also used string interpolation: #{} inside the string - it's much faster way to compile strings than using string + another_string. I also find it read easier as well.
            sachi
            Thank you very much
            it works just fine
