Including Edge Lines in Renderings
I made a new image of a spaceship from the 3D Warehouse to demonstrate rendering of Edge Lines.Edge lines can be important for detail. (Especially for items like wood cabinets where the detail is important.)
There are two ways to render Edge Lines - You can extract an image from SketchUp of just the edge lines, and then paste it on top of the rendered image or you can create 3D geometry from the edge lines, and add it to the model before rendering.
This first image uses full 3D geometry for the Edge Lines. The full 3D edge lines are reflected properly in other geometry. The overlay of SketchUp edge lines would not be visible in reflections.
Here is the same scene rendered without edge lines.
If you wanted edge lines for just part of the model, could identify which edge lines you wanted - e.g. by color - and then include only those edge lines.
Register LoginAdvertisement
