    SimLab 3D PDF for SketchUp verison 3 released
    7 Posts 4 Posters 1.3k Views 4 Watching
      ashraf
      SimLab Soft releases today the new major release (3.0) of 3D PDF exporter for SketchUp.
      This new release adds many great new features, new features include:
      Template Designer
      The newly added template designer enables users to create stunning templates easily to be used in 3D PDF export.
      Ready templates are included, ready templates can be customized in few clicks to reflect the spirit of the product
      Embed 3D PDF files into HTML
      The new SimLab 3D PDF exporter for SketchUp plugin gives users the ability to share the generated 3D PDF files on the web.
      Users can select any of the provided templates to generate HTML files that include their 3D PDF files.
      Merge PDF files
      SimLab 3D PDF exporter for SketchUp includes a new tool for merging multiple PDF files. Users can use the merge feature to merge a company’s front page –in PDF format– with 3D PDF models.
      Better 3D PDF illustration mode
      With the new illustration viewing mode, share your models in a new better look, showing details like never before.
      Open After Export
      The ‘Open file after export’ option makes it easier for users to view their generated 3D PDF files, without having to search for them.
      Floating Licenses
      It is now easier for larger teams to use SimLab 3D PDF exporter for SketchUp, by utilizing the new floating licenses
      To Download the new version on Windows and Mac, please click here
      • H Offline
        HPW
        Hello,
        On the download page you can read: The plugin is supported on SketchUp 8 ...
        So question: Is Sketchup 7 also supported/usable ?
        Regards
        Hans-Peter
        Edit: Got an answer by mail
        Yes the plugin should work with both SKP7 and 8 (free and pro)
        Best Regards,
        SimLab Soft
        • kenK Offline
          ken
          OK, I am confused. Is SimLab 3DPDF the same program as SimLab Composer 2.4? And if they are the same program, is there a paid or free update?
          Thanks for your reply.
          Ken
          • H Offline
            HPW
            Hello,
            SimLab 3DPDF (now V3) is the plugin only:
            http://www.simlab-soft.com/3d-plugins/3D-PDF-from-sketchup-main.aspx
            SimLap Composer (now V2013) is the full product:
            http://www.simlab-soft.com/3d-products/simlab-composer-compare-editions.aspx
            There is a upgrade price for 2.X
            Regards
            Hans-Peter
            • aadbuildA Offline
              aadbuild
              Hi Hans, I think your plug in is fantastic I do have a question that I hope you can help me with. When I export the model and open the PDF the image is off in the distance. I tried enlarging the image out of scale but it still have to zoom in. That is okay for me but clients open the house and see nothing except a speck in the distance. I also saved scene camera views and they are also in the distance.
              Can youlet me know how to work around this so I get a zoom extents image first up?
              andrew at aadbuild com
              Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
              https://www.plusspec.com
              • H Offline
                HPW
                Hello,
                It s not my plugin, I only evaluated it.
                Contact simlab support with your problem.
                Regards
                Hans-Peter
                • aadbuildA Offline
                  aadbuild
                  Sorry Hans thanks for reply, I ended up sorting it out.
                  Here is my independent review.
                  For anyone that is using this plug in: if you want the model to be visible in the PDF you need to use perspective under camera menu. Parallel projection will take you out into space and make models difficult to find. Scenes do not work in parallel projection so forget about showing a 2D parallel plan as the program does not implement zoom extents in parallel projection.
                  Also another note that I find frustrating is that the program will hang and ultimately relate in a bug splat if you minimise the screen and then reinstate at time of export. "I had it hang 8 times and restarted the model 8 times" loosing minor changes so if you intend on using this program save before you export. In saying that the most frustrating thing about buying the product is how long it takes to get a license after you pay your money.
                  All in all the product is not bad, it renders well and is efficient but it is not perfect if you are in a hurry (like I usually am 😳 ). I hope Simlab takes this as constructive feedback and rectify the problems without charging for an update. I will let you know how I go.
                  @hpw said:
                  Hello,
                  Regards
                  Hans-Peter
