    Should we be autoloading?
    4 Posts 3 Posters 411 Views 3 Watching
    • thomthomT
      Just thinking out loud here...
      Since the SketchUp Ruby API environment is a shared one - would it not be best practice for us (developers) to use autoload instead of require?
      This would not be feasible with scrambled ruby files as they rely on Sketchup::require - but for all the unscrambled ruby files. The majority is unscrambled. And users have many many plugins installed - often they will use only a fraction of them.
      I'm not expecting a major memory benefit - but I do think that we could expect improvement in SketchUp startup times.
      (Sidenote - I do suspect that toolbar creation is a major component in the startup time. Something that ought to be investigated.)
      Fire at will!
      • A
        Aerilius
        That sounds interesting.
        It's not "thread safe" but I don't think that matters for us.
        Symbols don't support colons, so nested modules would be done like in the comments here: http://www.rubyinside.com/ruby-techniques-revealed-autoload-1652.html
        How much would be the performance gain?
        One could do some testing (I'll do this evening) like plugins normal, plugins disabled, plugins with autoload.
        • Dan RathbunD
          Dan Rathbun
          I remember trying this a long time ago.. but did not get it working. Maybe I used it wrong?
          As I remember it loads modules, not scripts. So perhaps the name of the script must be the same as the module ?
          I'm not here much anymore.
          • thomthomT
            I do have it working for a large project I'm working on. I set up some of the mixing modules and base classes to autoload.
            <span class="syntaxdefault"><br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Ensure&nbsp;abstract&nbsp;classes&nbsp;are&nbsp;loaded&nbsp;and&nbsp;found&nbsp;when&nbsp;needed.<br />&nbsp;&nbsp;</span><span class="syntaxdefault">autoload</span><span class="syntaxkeyword">(&nbsp;;</span><span class="syntaxdefault">Observable</span><span class="syntaxkeyword">,&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">PATH</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'observable.rb'&nbsp;</span><span class="syntaxkeyword">)&nbsp;)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">autoload</span><span class="syntaxkeyword">(&nbsp;;</span><span class="syntaxdefault">BezierEntity</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">PATH</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'bezier_entity.rb'&nbsp;</span><span class="syntaxkeyword">)&nbsp;)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">autoload</span><span class="syntaxkeyword">(&nbsp;;</span><span class="syntaxdefault">BezierPatch</span><span class="syntaxkeyword">,&nbsp;&nbsp;</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">PATH</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'bezier_patch.rb'&nbsp;</span><span class="syntaxkeyword">)&nbsp;)<br />&nbsp;</span><span class="syntaxdefault"></span>
