I must be dumb
As a matter of fact, I am dumb.
I have written this piece of code to rotate a group or component around its bounding box's center. It works for the red and the green axis, but not for the blue one. Ridiculously, I can't see why. Probably I've spent too much time on this one. Can you help?
Thanks a lot,
Thierryclass Rotate def Rotate;;move if checkselection(true) obj = nil obj = Sketchup.active_model.selection[0] box = obj.bounds p = Geom;;Point3d.new(box.center) values = 0.0, 0.0, 0.0 results = inputbox ["X (Red)","Y (Green)", "Z (Blue)"], values, "Rotation" return if not results x, y, z = results count = 0 if x != 0.0 count = count + 1 end if y != 0.0 count = count + 1 end if z != 0.0 count = count + 1 end puts x puts y puts z if count == 0 UI.messagebox "Nothing to process!" return nil end if count > 1 UI.messagebox "Only one rotation at a time, please!" return nil end if x != 0.0 rv = Geom;;Vector3d.new(1.0, 0.0, 0.0) ra = x.degrees end if y != 0.0 rv = Geom;;Vector3d.new(0.0, 1.0, 0.0) ra = y.degrees end if z != 0.0 rv = Geom;;Vector3d.new(0.0, 0.0, 1.0) ra = z.degrees end trans = Geom;;Transformation.new(p, rv, ra) obj.transform!(trans) else UI.messagebox "Only Groups and Components can be rotated!" end Sketchup.active_model().active_view().invalidate end def Rotate;;checkselection(lock_check) sel_obj = Sketchup.active_model.selection[0] if sel_obj case sel_obj.typename when "Group","ComponentInstance" return nil if (Sketchup.active_model.selection[0].locked? & lock_check) return true end end return nil end end -
Hi Thierry,
The code works for all 3 axes for me.
I did see some better ways to code this in Ruby, but I didn't see any problem with your logic.
What you explain more what "doesn't work"? Exactly what happens, and what did you expect? Any errors?
Register LoginAdvertisement
