    Creating faces from points or edges fails
    7 Posts 3 Posters 750 Views 3 Watching
      tafkab76
      Hi!
      I´m trying to create a face consisting of four edges. Therefore I create the four (connected) edges with the enitites.add_edge method and store the resulting edge-objects in an array. When I try to draw a face by entities.add_face with the array containing the four edges I receive the following error:
      Error; #<ArgumentError; wrong number of values in array>
      which is strange, because this is what´s in the Array:
      [[#<Sketchup;;Edge;0xb7c1ba8>], [#<Sketchup;;Edge;0xb7c189c>], [#<Sketchup;;Edge;0xb7c1590>], [#<Sketchup;;Edge;0xb7c1284>]]
      Then I tried to draw the face using all the Point3d-objects by collecting them in an Array while drawing the four edges. When I try to draw the face with the Array of points as an argument I get the error that there are duplicate points in the Array. I tried to remove the duplicate points with the uniq-method, but that doesn´t work. I assume, uniq only works with primitive-datatypes and not with points since the array contains only referneces?
      So my three questions are:
      1. Why cant the face be drawn with the Array of edges as an argument?
      2. Is there an easy way/plugin to delete duplicate points from an array?
      3. Is there a better approach to achieve my goal of drawing a face with four given edges?
      Here is my so far code:
      <span class="syntaxdefault"></span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'sketchup.rb'<br /><br /></span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">send_action&nbsp;</span><span class="syntaxstring">"showRubyPanel;"<br /><br /></span><span class="syntaxdefault">model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />entities&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br /><br /><br />UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"PlugIns"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Bauteile"</span><span class="syntaxkeyword">)&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">dialog&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">WebDialog</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"Bauteile"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"SketchUp"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">460</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">600</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">100</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">100</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">dialog</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_file&nbsp;</span><span class="syntaxstring">"C;/Program&nbsp;Files&nbsp;(x86)/Google/Google&nbsp;SketchUp&nbsp;8/Plugins/bauteile/frontend_bauteilerstellung.html"<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">testString&nbsp;</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"0p0p0ae10p0p0k10p0p0ae10p10p0k10p10p0ae0p10p0k0p10p0ae0p0p0"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">kantenStrings&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">testString</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"k"</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">kantenArray&nbsp;</span><span class="syntaxkeyword">=&nbsp;Array.new<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">punktArray&nbsp;</span><span class="syntaxkeyword">=&nbsp;Array.new<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">kantenStrings</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">k</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">punkteString&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">k</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"ae"</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">anfangsPunktString&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">punkteString</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"p"</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">endPunktString&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">punkteString</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"p"</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">anfangsPunkt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">anfangsPunktString</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_i</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">anfangsPunktString</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_i</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">anfangsPunktString</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_i</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">endPunkt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">endPunktString</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_i</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">endPunktString</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_i</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">endPunktString</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_i</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">punktArray&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">anfangsPunkt<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;punktArray&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">endPunkt<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;kante&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_edges&nbsp;anfangsPunkt</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">endPunkt<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;kantenArray&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">kante<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;puts&nbsp;kantenArray</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">inspect<br />&nbsp;&nbsp;&nbsp;&nbsp;puts&nbsp;punktArray</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">inspect<br />&nbsp;&nbsp;&nbsp;&nbsp;punktArray&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">punktArray</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">uniq<br />&nbsp;&nbsp;&nbsp;&nbsp;puts&nbsp;punktArray</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">inspect<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;flaeche&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face&nbsp;kantenArray<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#flaeche&nbsp;=&nbsp;entities.add_face&nbsp;punktArray<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">dialog</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_action_callback</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"zeichne_flaeche"</span><span class="syntaxkeyword">)&nbsp;{|</span><span class="syntaxdefault">dialog</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">params</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">dialog</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show<br /></span><span class="syntaxkeyword">}&nbsp;</span><span class="syntaxdefault"></span>
      "testString" is just a...well testString which simulates the data I will later receive from the webDialog. It´s then parsed into edges. That works, since I can see a square in Sketchup.
      "kantenArray" is the Array containing the four edges
      "punktArray" is the Array containing eight Points, with four of them having the same coordinates
        tafkab76
        I just found out the answer to question number 1:
        since "add_edges" returns an Array of edge (also only 1 edge ist created), only the first (and only) value of the return value must be put into the Array of edges:
        wrong:
        kante = entities.add_edges anfangsPunkt, endPunkt kantenArray << kante
        correct:
        kante = entities.add_edges anfangsPunkt, endPunkt kantenArray << kante.first
          Or, since you only add one edge at a time - use add_line instead.
          kante = entities.add_line( anfangsPunkt, endPunkt ) kantenArray << kante
            However, I recommend you collect the point first, then when you have them all create all the edges in bulk with add_edges - it has much better performance.
            • Dan RathbunD Offline
              Dan Rathbun
              Also be aware of Ruby's expand/contract operator *
              If the method only takes a list of values, you can expand an array into an argument list like:
              some_method( *kantenArray )
              I'm not here much anymore.
                tafkab76
                Thanks for your advice, I denfinateley will keep that in mind...or at least try to...
                In case I follow your tip with collecting all points first and then create all edges with one single add_edges-command I would still have the problem of the duplicate points. That could quite easily be solved by an own "uniq"-method for Point3d-objects, but then the order of the points in that array could became disarranged, depending on which duplicte entry will be deleted. So I´m afraid my square could easily end up as an sandclock-shaped drawing.
                Since I have to draw about 20 faces at most, I will try the edge-by-edge method first.
                  Actually - no. #uniq will not compare Geom::Point3d against their positions - but rather if they are the same object instance.
