    SKETCHYPHYSICS TUTORIAL
    4 Posts 2 Posters 6.2k Views 2 Watching
    • chriC Offline
      chri
      %(#0000FF)[Hello
      After using SKETCHYPHYSICS and seeing that there is only few tutorials in french , i have write this little one .
      I have done a translation and hope you like it
      If you like , you can :
      improve the translation ( i'm french )
      revise it
      improve it
      and post new release ...
      bye
      chri from SKETCHYPHYSICS community]
      UTILISATION DE SKETCHYPHYSICS 20120331 anglais.xls
      • simon le bonS Offline
        simon le bon
        Hi Chris,
        Thank you for this tutorial ++
        Here is the missing link to your initial french tutorial:
        UTILISATION DE SKETCHYPHYSICS les bases
        http://forums.sketchucation.com/viewtopic.php?f=51&t=41757&p=369950
        (we probably have to be registered to the french forums to be allowed to access it !?)
        simon
        • chriC Offline
          chri
          hi
          others links :
          http://sketchyphysics.wikia.com/wiki/SketchyPhysicsWiki
          http://www.niutec.nl/Tekenen/SketchUp/Plugins/SketchyPhysicsTutorial.pdf
          http://support.ponoko.com/entries/21249896-gears-and-joints-with-sketchup-sketchy-physics
          Error 404 (Not Found)!!1
          (code.google.com)
          http://sketchup.google.com/3dwarehouse/cldetails?clid=87a7362c04022da1488c4d0670505cd5
          http://sketchucation.com/forums/viewtopic.php?f=61&t=48625
          http://www.fmzik.com/video_wgwNuNRRnZs_Sketchy-Physics-Tutorial-pt.3.html
          bye
          • chriC Offline
            chri
            %(#0000FF)[hello
            last update in french
            Suite à l'utilisation de SKETCHYPHYSICS et devant le peu de tutoriels en français, voici quelques notes que j'ai prises .
            Peut-être, pourrons-t-elles aider quelques collègues et constituer le départ d'une doc.
            @simon le bon
            Bonjour Simon , thanks for your encouragement 👍
            bye
            chri]
            UTILISATION DE SKETCHYPHYSICS 20120331.xls
