    BitBucket Basics / Git Tips
    6 Posts 2 Posters 736 Views 2 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Set up my first Git repo at BitBucket, (and although I am going through the Tutorial,) I'd like to create this topic here for tips on using Git and/or BitBucket, to develop a project specifically for SketchUp Ruby.
      πŸ’­
      I'm not here much anymore.
        Dan Rathbun
        First question... what should the Wiki page be ?
        If I create a README at the top of the Git repo, is it displayed as the Wiki by default. (And conversely, if I edit the Wiki manually, is it saved as as the README file ??)
        I know there needs to be project introduction, and I'd also like somewhere to list the goals of the project for first release at v1.0.0, and it seems like this is a good place.
        But also... since this is a library project, .. we need a place to display the API (whether manually written, or RDoc generated. And the Wiki seems also to be a nice place for this, (but maybe I am missing some Documentation feature of BitBucket ??)
          Dan Rathbun
          It seems the project / repos are missing a discussion feature, where general issues or strategy for the project can be discussed.
          I would not think we would wish to fill up the Issues List will this kind of general discussion.
          So we'd need to create either a GoogleGroup, or a Beta Forum here at SCF, for the project ??
            Dan Rathbun
            Local Repo / Plugin Testing Syncronization
            OK, I followed the Tutorial and made my "repos" dir in my HOME dir.
            Created (cloned) the project in that dir, let's call it "repos/proj"
            Previously, I was working on my project in a subdir of SU's "Plugins" dir. This makes it handy for loading and debugging.
            So I manually copied the entire project dir hierarchy to "~/repos/proj" and used the Git GUI to commit and push the first version of the code to the online Git repo at BitBucket.
            All seems well so far.
            But now, I need to continue editing the code, testing it, and pushing updates.
            The question is... do I work on the set under the "SketchUp/Plugins" dir, and manually copy to the local repo, or reset my Notepad++ session to open files from the "~/repos/proj" dir instead ??
            I imagine that I can put a script in the "Plugins" dir, that appends the path File.expand_path("~/repos/proj") to Ruby's $LOAD_PATH array, so I can load and debug directly from there.
            Is this what others are doing when they use Git for SketchUp Ruby development ???
              I like to use the Issues BitBucket service on my repos - so I can mark issues as solved on push.
              https://confluence.atlassian.com/display/BITBUCKET/Setting+Up+the+Bitbucket+Issues+Service
                Dan Rathbun
                Great Idea, I was wondering how to do that. Done.
