    Can Sketchup receive Window message?
    7 Posts 3 Posters 385 Views 3 Watching
    • D
      Debbie
      This is what I've done so far: wrote a plugin using "Win32API" to send message to other program (e.g. tell ABC.exe to calculate sth..). But now I want to let SU knows the calculation is finished in ABC.exe (e.g. may be sending WM_COPYDATA message back to SU). Is there any callback function in SU can be used to check it?
      • Dan RathbunD
        Dan Rathbun
        OR.. you could create a hidden Win32 window (off screen,) with an edit control, and send the data to that control.
        When the control is populated, you read it with Win32API call from Ruby.
        I'm not here much anymore.
        • D
          Debbie
          Thank you so much!! The ABC.exe is written by me and I will take a look at Win32ole first. πŸ˜„
          By the way, I have been thinking about using DLL to receive message and then call a ruby function to collect the data. But it seems not easy to run ruby on Visual studio so I finally give up. 😒
          • thomthomT
            Maybe you can make a Ruby C Extension work for you?
            • Dan RathbunD
              Dan Rathbun
              No, sorry. The reason is the API tries to be cross-platform, and I believe OSX does not use inter-window messaging like MS Windows does.
              Did YOU write the program ABC.exe ???
              Or is ABC.exe a command line program, and does it output it's results to STDOUT ??
              If so, use "win32ole.so" (class WIN32OLE in Ruby,) instead of Win32API.
              http://msdn.microsoft.com/en-us/library/ateytk4a(v=vs.84)
              The Ruby version looks most like the Javascript example.
              Ref:
              http://www.ruby-doc.org/docs/ProgrammingRuby/html/lib_windows.html
              and "Windows Automation" on this page:
              http://www.ruby-doc.org/docs/ProgrammingRuby/html/win32.html
              Also.. search this forum for examples of using the Windows Scripting Host via class WIN32OLE in Ruby.
              • D
                Debbie
                Ruby C extension? seems useful! thanks.
                • thomthomT
                  I made a Hello World project for getting Ruby C Extensions to work under SketchUp:
                  https://bitbucket.org/thomthom/sketchup-ruby-c-extension
