    [Plugin] projectEditor_dj v1.8.SU.2013-14
    24 Posts 3 Posters 32.3k Views 3 Watching
    • dukejazzD Offline
      dukejazz
      Copyright march 1, 2014
      DukeJazz: via James Cochran
      ProjectEditor_dj: ( This editor platform sets up accurate sizes and precision placements for 2d and 3D printing projects or laying out virual scene arrangements )
      1. Another_Sketchup_dj (move clipboard objects from parent to child and back
      2. Another_Sketchup_Plus_dj ( selection or all duplicator, group, un-group, make centers, program loader + more
      3. scaleGroupFloat_dj ( scale, cumulative-scaler, alignment mover, undo tools
      4. ZoomZoom_dj (zoom select tools)
      5. Plugins_loader_dj (shows and hides my toolbars)
      6. Tips_dj ( my personal tips to working with plug-in )
      One button toolbar plug-in loader for all my plugins files
      hide all=off
      show=projectEditor_dj= all on
      History:
      march 1 2014 projectEditor_dj v1.8.SU.2013-14
      -fix table errors
      -add .rbz endings 2014
      June 18, 2013; projectEditor_dj v1.7 make 2013.m1
      -new scaleGroupFloat_dj full inputbox format
      -new selectAll fix
      -fix icons
      -fixes for make 2013 m1
      -set module to LibAnotherScalePlusDJ
      -changed to self.method
      -move varaibles table to DJ_lib folder,
      -djAnotherLib_dj.rb thus DJ::LibAnotherScalePlusDJ.variables_dj
      -deleted two folder hidden and unhidden
      April 18, 2013; projectEditor_dj v1.6.5 bata
      add the scaleGroupFloat_dj v1.6.5
      -add cumulativeScaler_dj rotation around
      Feb 4, 2013; projectEditor_dj v1.6.1 bata
      -change to a toogle tool bar
      Feb 4, 2013 anotherSketchup_dj_loader v1.6
      • add Slect all, delete and paste in place
        Feb 4, 2013; scaleGroupFloat_dj v1.6 bata
        -add cumulativeScaler_dj move around (a step boxpoint)
        -add cumulativeScaler_dj size lenear stepper
        -add cumulativeScaler_dj move lenear stepper
        -fixes
      2012, July 23 - release date
      download:
      March 1, 2014; projectEditor_dj v1.8.SU.2013-14
      projectEditor_dj ver1.8 .rbz
      June 18, 2013; projectEditor_dj v1.7 make 2013.m1 bata 6,7,8,2013
      projectEditor_dj v1.7.zip
      April 18, 2013; projectEditor_dj v1.65 bata
      dj_plugins v1.65.zip
      Feb 4, 2013; projectEditor_dj v1.6 bata
      projectEditor_dj v1.6.1 .zip
      • dukejazzD Offline
        dukejazz
        moveSize2Target_dj
        Makes a target point from a selected object and them it will moves or resizes other objects to that target point.
        • dukejazzD Offline
          dukejazz
          How to work ea tool (WIP)
          1. scaleGroupFloat_dj Ver 1.3.0 http://forums.sketchucation.com/viewtopic.php?f=323&t=45254
          2. Another_Sketchup v1.5 http://forums.sketchucation.com/viewtopic.php?f=323&t=42219
          3. Another Sketchup Plus Ver.1.5 Bata http://forums.sketchucation.com/viewtopic.php?f=323&t=42951
          • dukejazzD Offline
            dukejazz
            Update
            dj_plugins V1.3.Zip
            History:
            Aug 3, 2012 ver 1.3
            -add one new tool moveSize2Target_dj
            -repacked the toolbars 2ea
            • dukejazzD Offline
              dukejazz
              sep 16 2012
              update - plugins_dj v1.4 = projectEditor_dj v1.1
              update - scaleGroupFloat_dj Ver 1.5 Big changes here
              bbox to local axes readout
              also method to aline to orgin axes
              update - moveSize2Target_dj Ver 1.1
              update - another Sketchup v1.5.1
              update - repeatUndoTool_dj v1.2.1
              update - drawBoxPoint_dj.rb v 1.1
                "Bata" = "Beta"? πŸ˜•
                • dukejazzD Offline
                  dukejazz
                  Always room for improvements
                  Changes I would like to make:
                  Is there a way to turn off undos function in a ruby program?
                  A better inputbox with object and mouse usage to drawing model without closing inputbox?
                  Make scaling to a local axes?
                  Add rotation memory to target to move to a rotation?
                  Add more plugins.
                  Bata Bata work yes πŸ‘
                    No. You cannot turn off Undo. You can make them transparent - but it's not quite the same and it's very easy for things to go wrong.
                    Btw, you have a lot of global methods and variables. I recommend you wrap your plugins in a separate namespace - otherwise you have a potential for clashing with other plugins and each methods in the global namespace end up in every other object in Ruby.
                    Detailed explanation: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/
                      @dukejazz said:
                      A neat way maybe for me to output a save name.skp then import the name.skp file back after a count of undos for my program block of execution.
                      ? What are you trying to do then?
                      You are aware you can group operation, right? With model.start_operation and model.commit_operation.
                      https://developers.google.com/sketchup/docs/ourdoc/model#start_operation
                      • dukejazzD Offline
                        dukejazz
                        May fast undos is stable as is but it uses the clipboard, I would not like to do this because good data maybe over ridden at some time.
                        • dukejazzD Offline
                          dukejazz
                          Thank you, for the lead I will try this.
                          Also all my @varaibles are @dj_name @dj_ you say may varible names maybe to small and use by someone else I thought @H or @@u were global varibles and my initial values @dj_ were not? I can't run my rubies meathods def by another ruby, without sending my own initial values with them. I can go down the heap but not out. I been working with ruby for 6 mo. no classes! so i dont know a whole lot so thank you for your helping head up.
                          • dukejazzD Offline
                            dukejazz
                            update to five of my plugins
                            • fix Clipboard undo's, is now a one step process
                            • fix My def are now wrap up as _scaleGroupFloat_dj
                            • fix var are now wrap up to djscaleGroupFloat_x[][]
                            • I recoded some of my varibies table to fix some of my rubies programs
                            Fix the undo's problems by pairing these statements
                            Sketchup.active_model.start_operation "dj_Group",true,true,true
                            copy_group = Sketchup.active_model.active_entities.add_group(@djScaleGroupFloat_sents)
                            copy_group.explode
                            Then at the end of the program
                            Sketchup.active_model.commit_operation
                            global namespace - Done
                            global methods - Done
                            next:
                            class
                            web ding dong
                              Aerilius
                              Variables that start with @ or @@ ar not global variables. And if they were, it would be good not to use them. Global variables start with a $. There are two reasons why to avoid global variables:
                              • to avoid name clashes (two different plugins that use the same name. Ok, that is less likely if you use long variable names or prefixes like $dj_variablexy)
                              • to avoid messing up the global (Kernel) namespace
                              I was wondering about the method initialize in %(#000000)[scaleGroupFlat_dj_loader.rb:85], I don't see in which class it is (or how it works). Did I miss module/class definitions? There are many methods that appeared to be in the global name space (not in a module) in files:
                              β€’ entlast.rb
                              β€’ scaleGroupFlat_dj_loader.rb
                              β€’ anotherSketchup_dj_loader.rb
                              β€’ anotherSketchupPlus_dj_loader.rb
                              β€’ tips_dj_loader.rb
                              It is always a good idea to wrap code into modules, like:
                              module DJ
                                module AnotherSketchupPlus
                                  def self.youSU_clearCbExit
                                  # ... (other methods)
                                end # module AnotherSketchupPlus
                              end # module DJ
                              P.S.: I like the forum's formattin****g tools – they make text much nicer and readable and sometimes funny πŸ˜‰
                              • dukejazzD Offline
                                dukejazz
                                projectEditor_dj 1.5.4 |new name to fit what job action they do| old - dj_plugins v1.5.3
                                Copyright Dec 26 2012
                                by DukeJazz: James Cochran
                                Big new these programs are safe to use, now in module format
                                module DJ
                                module Plugins
                                History:
                                Dec 26 2012 v1.5.4
                                • All plugins wrap in Module DJ::pluginsName.method_dj(name space)
                                • All @variable format (name space) dj_variable
                                • All plugins are in subject and name order (easy to look up)
                                • Name changed from dj_plugins_loader to projectEditor_dj
                                  Why is there a hidden file in the package? "dj_plugin_loader.rb" ?
                                    There are lots of them... ?
                                      But why do you package and distrobute a ZIP file full of old and hidden files?
                                      Even though the RB file is hidden it's loading.
                                      • dukejazzD Offline
                                        dukejazz
                                        Name change
                                        you may delete the old if you want
                                        I didn't want a conflick with old still running
                                        "Make ruby .rb or.rbs attributes hidden to keep plugins from loading at sketchup startup. ."
                                        Select ( the hidden or unhidden folder ) files... and copy them to SU plugins folder for a boot startup of each tool.
                                        • dukejazzD Offline
                                          dukejazz
                                          Now that it's as a hidden file. dj_pligins_loader.rb It can later be excluded from later ver.
                                          On my compter I have 754 rb files and 550 are hidden in my plugins folder and they won't be loaded unless they are unhidden at sletchup startup
                                          yes thomthom; thomthom Β» Today, 4:53 am
                                          They will load if you call them thou the ruby script loader
                                          I given you these folders (unhidden and hidden) so you don't need to work throu the mess of finding and changing the plugins loaders (copy and drop the file to plugins folder of what you want to hide)
                                          I did find two desktop.ini files, I will delete them now
                                          This one dj_plugins folder hold all my tools rb and if updated all platform are too.
                                          I kind of address them all.
                                          • dukejazzD Offline
                                            dukejazz
                                            projectEditor_dj 1.6 || old - dj_plugins v1.5.3
                                            Copyright Feb 4, 2013
                                              -fixes
                                              Feb 4, 2013 anotherSketchupPlus_dj v1.6
                                            • add explode; to componet; explode now dose both group and componet.
                                              Feb 4, 2013
                                              -added more Tips
                                              Copyright Feb 4, 2013; zoomZoom_dj v1.6
                                              -grouping to projectEditor_dj v1.6
                                            • 1 / 2
