    Overflow bug?
    2 Posts 2 Posters 183 Views 2 Watching
      This is part of a snippet I use to get the orientation of the custom set axis.
      <span class="syntaxdefault"><br />entities&nbsp;</span><span class="syntaxkeyword">=&nbsp;@</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br />tr&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">transformation<br /></span>
      I've used it to extract the x, y and z axis from the transformation.
      However, today I tried to use the transformation object directly and got some strange results. Upon further inspections I found that the origin of the transformation was far out!
      [1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 1.0e+030, 1.0e+030, 1.0e+030, 1.0]
      Just to visualize the value:
      1.0e+030.to_l.to_s (eval):1017: warning: Float 1.0e+030 out of range 25399999999999999000000000000000,0mm
      The axis when I run is isn't in fact moved - so it the origin should be 0,0,0. I'm wondering if it's an overflow bug in SketchUp?
      • daikuD Offline
        daiku
        Probably the result of dividing by "almost zero". Which in turn could result from a floating point roundoff error.
        Clark Bremer
        http://www.northernlightstimberframing.com
