    VCB greyed out
    3 Posts 3 Posters 472 Views 3 Watching
    • D
      duke
      I'm making a fairly simple script called Thicken, thats basically a wrapper for JPP. My problem is that the VCB is greyed out - even after putting in enabledVCB?
      Does anything stand out here (I removed the guts between start_operation and commit_operation for debugging purposes)?
      ### NOTE; Dev. halted - couldnt get Measurements (VCB/Value Control Box) input working
      require 'sketchup.rb'
      require 'extensions.rb'
      require 'jointpushpull.rb'
      thickenExt = SketchupExtension.new "Thicken", "CKD_Thicken.rb"
      thickenExt.version = '1.0'
      thickenExt.description = 'Uses JPP to thicken the select face/s directly or inside the selected groups'
      Sketchup.register_extension thickenExt, true
      module Thicken
      def initialize()
          @thickness = 100.mm
          @model = Sketchup.active_model
          selectedEntities = model.selection
          thickenTool = ThickenTool.new(self)
          @model.select_tool thickenTool
          model.start_operation "Thicken"
          model.commit_operation
      class ThickenTool
      	def initialize(caller_class)
      		@caller = caller_class
      	def activate
      		Sketchup.set_status_text "Thickness", SB_VCB_LABEL
      		Sketchup.active_model.active_view.invalidate
      	def deactivate(view)
      		view.invalidate
      	def onUserText(text, view)
      		UI.messagebox("what")
      	def enableVCB?
      	   return true
      end #Class ThickenTool
      if( !$thickenLoaded )
          $ckdSubMenu.add_item("Thicken") { thicken }
          thickenLoaded = true
      end #Module Thicken
      • thomthomT
        First of all I get an error because $ckdSubMenu is not defined.
        I replace that with UI.menu('plugins') and I get a new error:
        Error: #<NameError: undefined local variable or methodthicken' for Thicken:Module>
        c:/thicken.rb:52`
        I cannot just replace thicken with Thicken.initialize because that is a private method. I replace that with def self.start_tool() and call that.
        I then get an error on selectedEntities = model.selection because model is not defined. I replace all model references with @model.
        Then, when all these errors are solved the Tool activates and the VCB works just fine.
        My question to you, did you even have the Ruby Console open when you tried your code?
        <span class="syntaxdefault"></span><span class="syntaxcomment">###&nbsp;NOTE;&nbsp;Dev.&nbsp;halted&nbsp;-&nbsp;couldnt&nbsp;get&nbsp;Measurements&nbsp;(VCB/Value&nbsp;Control&nbsp;Box)&nbsp;input&nbsp;working<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'sketchup.rb'<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'extensions.rb'<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'jointpushpull.rb'<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">thickenExt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">SketchupExtension</span><span class="syntaxkeyword">.new&nbsp;</span><span class="syntaxstring">"Thicken"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"CKD_Thicken.rb"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">thickenExt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">version&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">'1.0'<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">thickenExt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">description&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">'Uses&nbsp;JPP&nbsp;to&nbsp;thicken&nbsp;the&nbsp;select&nbsp;face/s&nbsp;directly&nbsp;or&nbsp;inside&nbsp;the&nbsp;selected&nbsp;groups'<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">register_extension&nbsp;thickenExt</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">true<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;module&nbsp;Thicken<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_tool</span><span class="syntaxkeyword">()<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">thickness&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">100.mm<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;selectedEntities&nbsp;</span><span class="syntaxkeyword">=&nbsp;@</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;thickenTool&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">ThickenTool</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select_tool&nbsp;thickenTool<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#model.start_operation&nbsp;"Thicken"<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#model.commit_operation&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">class&nbsp;</span><span class="syntaxdefault">ThickenTool<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;initialize</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">caller_class</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">caller&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">caller_class<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;activate<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_status_text&nbsp;</span><span class="syntaxstring">"Thickness"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">SB_VCB_LABEL<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">invalidate<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;deactivate</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">invalidate<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;onUserText</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">text</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"what"</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;enableVCB</span><span class="syntaxkeyword">?<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;</span><span class="syntaxdefault">true<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;</span><span class="syntaxcomment">#Class&nbsp;ThickenTool<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;!</span><span class="syntaxdefault">$thickenLoaded&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Plugins'</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Thicken"</span><span class="syntaxkeyword">)&nbsp;{&nbsp;</span><span class="syntaxdefault">Thicken</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_tool&nbsp;</span><span class="syntaxkeyword">}&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">thickenLoaded&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">true<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;</span><span class="syntaxcomment">#Module&nbsp;Thicken<br />&nbsp;</span><span class="syntaxdefault"></span>
        • Dan RathbunD
          Dan Rathbun
          Duke, ya need to get your files and folders organized (so you stop using global variables.)
          Separate the code into 3 files, thus:
          file: "Plugins/CKD_Thicken_ext.rb"
          ### #  "Plugins/CKD_Thicken_ext.rb"
          require('sketchup.rb')
          require('extensions.rb')
          module CKD
            module Thicken
              @@plugin = SketchupExtension.new "Thicken", "CKD/Thicken/CKD_Thicken.rb"
              @@plugin.version = '1.0'
              @@plugin.creator = 'CKD (aka "Duke")'
              @@plugin.copyright = '2012, CKD'
              @@plugin.description = 'Uses JPP to thicken the select face/s directly or inside the selected groups'
              Sketchup.register_extension( @@plugin, true )
            end # module Thicken
          end # module CKD
          file: "Plugins/CKD/CKD_module.rb"
          # "Plugins/CKD/CKD_module.rb"
          module CKD
            @@topmenu = UI.menu('Plugins')
            @@submenu = @@topmenu.add_submenu('CKD')
            @@menuitem = {}
            def self.menuitem()
              return @@menuitem
            def self.submenu()
              return @@submenu
            def self.topmenu()
              return @@topmenu
          end # module CKD
          file: "Plugins/CKD/Thicken/CKD_Thicken.rb"
          #  "Plugins/CKD/Thicken/CKD_Thicken.rb"
          require('jointpushpull.rb')
          require('CKD/CKD_module.rb')
          module CKD;;Thicken
              @@tool = nil
              class ThickenTool
                      @thickness = 100.mm
                  def activate
                      @selected = @model.selection
                      Sketchup.set_status_text("Thickness", SB_VCB_LABEL)
                      view.invalidate
                      @model = nil
                      @selected = nil
                  def resume(view)
                  def suspend(view)
                      nil
                      # call method thicken() here ?
                  def enableVCB?
                      return true
                  def thicken
                      model.start_operation("Thicken")
                          # change model here
                  rescue Exception => e
                      model.abort_operation
                      puts("Thicken Error!\n#{e.message}")
                      puts(e.backtrace)
              class << self # Proxy class
                def tool()
                    if @@tool.nil?
                        @@tool = CKD;;Thicken;;ThickenTool.new(self)
                    return @@tool
              end # Proxy class
              # RUN ONCE
              unless file_loaded?( 'CKD;;Thicken' )
                  CKD;;menuitem["Thicken"]= CKD;;submenu.add_item("Thicken") {
                      Sketchup.active_model.select_tool( CKD;;Thicken;;tool )
                  file_loaded( 'CKD;;Thicken' )
          end # module CKD;;Thicken
          I'm not here much anymore.
