    Arrange cabinets & clear cpoints-clines
    9 Posts 2 Posters 600 Views 2 Watching
    • jojo9J Offline
      jojo9
      i hope to post here in the right place to find some scripters able to write some very small scripts:
      1. i often organize a bunch of cabinets or similar many times. Would be nice to arrange things quicker leaving a ruby script to rotate groups/components:
        a) rotating all items in selection around a central axis (180°)
        a1) rotating every single item in the selection, but individually (180°)
        b) putting a group/comp perpendicular to the next nearest wall/ceiling/floor ( one possible directions using: x-y-z axes)
      2. i use contruction points and lines all the time but want more control over them
        c) deleting only visible cpoint-clines
        deleting only visible cpoint-clines = Selection Toy by Thomthom
        but not sure of what is only visible cpoint-clines ?
        the normal rotation tool don't make that ?
        rotate individually = Rotate multiple by Chris fullmer
        • jojo9J Offline
          jojo9
          Hi Pilou,
          …thanks for helping out. Arranging objects isn't so funny most of the time, because it requires you to do repetitive actions over and over again:
          1. you have to group the component cabinets you want to move from A to B and B to A, and do the rotation (180° globally)
          2. destroy the group, because the cabinets are in the right place now, but facing to the wall
          3. rotate every cabinet individually, to make them look forward (180° again but locally)
          Re-arranging cabinets with the push of a button would be much more simpler.
          And with deleting visible construction points/lines i meant it literally. I don't know you, but i move guides and cpoints on other layers as well. So i'm able to hide/unhide certain guides as i wish.
            like this ?
            if not post an image or a skp file (save as V6)
            • jojo9J Offline
              jojo9
              no it is not what i meant. (Don't worry) The cabinets should rest in their original corner, only exchanged. A should take the place of B and vice versa, but in the same corner. Hence you've to rotate your cabinets twice. I use the rotate and mirror tool very often, but to arrange… its laborious if you've to move more cabinets… 😐
                Except the rotation my example was what that you want 😉
                So try Component dropper by Thomthom
                That must help you for some special cases 😉
                Else random Replacement components by Sdmitch can also help you if you take just one component as source 😉
                and the normal menu Component / "Replace selected" also! 😉
                But for all that there is a little problem
                the own axis of all components and the general placement!
                So a move will maybe necessary depending of measures of each components
                  And just 2 moves don't make the trick ?
                  All take 3 seconds!
                  • jojo9J Offline
                    jojo9
                    Pilou,
                    i use Sketchup some time now and know what i need. Different people, different needs- its nice from you to be interested-but take it with ease- i actually had to organize a lot of interiors and its not always funny, even having such a great tool as Sketchup.
                    Thank you for the understanding.
                      If you want that someone makes a plugin for you
                      post a file SKP (save as V6) with also an image before / after for avoid missunderstood problem 😉
                      Maybe your problem is trivial for a ruby coder, maybe not 😄
                      And this must work for any number of components ?
