    Copy Components at Defined Distances Along a Path
    7 Posts 4 Posters 675 Views 4 Watching
    • Bob JamesB Offline
      Bob James
      I know a plugin exists to Copy Components at Defined Distances Along a Path: I've used it before, but I can't find it. πŸŽ‰
      • BoxB Offline
        From smustard not local.
        (www.smustard.com)
          Bob James
          Many, many thanks, Box 😍
          • cottyC Offline
            cotty
            Component stringer (Chris Fullmer) maybe also helpful:
            http://forums.sketchucation.com/viewtopic.php?t=23616#p200751
            my SketchUp gallery
              Bob James
              Thanks. Component Stringer doesn't let you specify the interval along the path. I tried it first. PathCopy was what I was looking for: I did all kinds of searches, but couldn't find it.
              • cottyC Offline
                cotty
                Component stringer lets you specify the intervals indirectly with the subdivision of the path:
                my SketchUp gallery
                • McGyverM Offline
                  McGyver
                  Hi. Your post reminded me of a similar question I was going to ask here a while ago, but I never got around to asking.
                  Today I went looking for and found the Plugin that I was going to ask about, thanks to your post...
                  Component Spray:
                  http://forums.sketchucation.com/viewtopic.php?t=33908
                  I know I used it to make a model that needed evenly spaced columns arrayed along a path... but I'm not sure if it was an easy workflow...
                  If you go to this page, down to plot-paris's post with the image showing column placement you can see what I mean:
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=11746
                  Hope this of some use... good luck.
                  Visit My ShareCG Freebie Gallery
