    Plugin Request / Tweak Request - Protrude
    7 Posts 4 Posters 1.1k Views 4 Watching
    • H Offline
      haynesc
      Hi all
      I was wondering if there is an update for protrude or another tool that is similar to do the following Process
      Selected all ...
      Extrude randomly using the following heights:
      Min : [User specified height) 8
      Max : [User specified height) 24
      @ 8,12,16,20
      So instead of random heights between 8 & 24, the heights will be of only values 8,12,16,20 or 24
      Thanks Chris
      • H Offline
        haynesc
        that would require creating loads of components and would take longer
        I have lots and lots of loose geometry from CAD to mass up and what would be perfect is protrude but with a bit more customization fields ...
        I couldnt find protrude author who shall i contact ?
          Use the tricky Random Components remplacement by Sdmitch πŸ˜‰
          If you have different forms use five times Random Selection of TIG + Selection Toys by Thomthom for have only faces before the JPP
          and the JoinPushPull by Fredo6 πŸ˜‰
          Random select, Selection only face
          Delete Copy Move (Ctl+X, Ctrl +V) Apply the JPP
          five times but some complex πŸ˜„
            Of course yes, i believe that is Jim πŸ˜‰
            His site β˜€
            You have a contact inside! 😎
            • sdmitchS Offline
              sdmitch
              @haynesc said:
              Hi all
              Selected all ...
              @ 8,12,16,20
              Thanks Chris
              Give attached plugin a try. I think it will do what you want.
              Random Protrusion Ver. 1.0
              http://sdmitch.blogspot.com/
                the.pjt
                wow πŸ‘ ... you are so fast SAM ... Great plugin ... thanks sam .. and please don't hate me πŸ˜‰ ...
                  Genious! 😎
                  The circular form is made with the tricky plug of TIG Split Sausage from the 3 Split Tools! β˜€
                  The divisions of the plan and cube are made by the Original Protrude by Jim πŸ˜‰
