    1st Interior Render Test - UPDATED
    10 Posts 5 Posters 1.2k Views 5 Watching
    • Bryan KB
      This is my first interior render test with Kerky.
      All models were imported from the Warehouse.
      It still needs some tweaking. There will be some other changes. I will also attempt a day scene.
      • allanxA
        allanx
        Nice one Bryan...This is good for a first time interior render.
        allanx
        Portfolio
        • Bryan KB
          allanx
          Thanks!
          I'll be using this as my training and testing model. There will be several variations posted.
          • allanxA
            allanx
            You could play around with nice and much larger textures for your walls and floor if you are doing another variations of these renders... πŸ˜‰
            allanx
            Portfolio
            • Bryan KB
              Update
              • Bryan KB
                Another update
                • V
                  vidy
                  Congrats for your first interior render..
                  Its looking nice already, but maybe if the light edge have a bit softness and the curtain was a better model, the render will look better
                  keep it up..
                  regards,
                  still so much to learn..
                  • davids90gtD
                    davids90gt
                    It looks like all of your light sources have soft shadows turned on except for the can lights. Right click on the desired light (in the left hand menu bar), go to "edit light" and check the box "soft shadows"
                    • N
                      notareal
                      Indeed soft-shadows seems disabled, you will get much better shadows if you enable that (just edit light components with right click in KT). Also make sure that Radiance Attenuation is set to "Inverse Square".
                      • Bryan KB
                        Thanks Dave and notareal. I'll give that a try.
