    Plugin to Cleanup or Normalize Definition Names?
    4 Posts 3 Posters 538 Views 3 Watching
    • J
      Jim
      Is there a plugin already that can remove the #1, #2, #N from Definition names?
      • sdmitchS
        sdmitch
        Since definition names must be unique, just removing them would not be allowed but the #1 etc. could be replaced as long as the name remained unique.
        http://sdmitch.blogspot.com/
        • R
          rocorona
          ...or you made IDENTICAL components from identical groups or elements, and want to UNIFY them (to have only one definition).
          This can't be done changing the definition names, but selecting the components, then right-clicking to the Component you want to switch to, in the Component Browser, and selecting the "replace" command.
          • J
            Jim
            Thanks, I understand the limitations. I just wanted something to clean-up carelessly-named components. I was also thinking about a plugin for renaming definitions based on their "_name" atributes (for DC's) so the component names in the Outliner and the names in the Dynamic Attributes editor matched up.
