    [Code] Set class fix v0.3.2
    9 Posts 3 Posters 2.0k Views 3 Watching
    • Dan RathbunD
      Dan Rathbun
      Here's a little script that "fixes" the conflict issue between Ruby's Set class and the API's Set class.
      Note: This issue has been fixed in SketchUp 2014
      This file is not needed, but v0.3.2 should do nothing if loaded under SketchUp 2014.
      A full ruby install is needed.
      Testing, Thoughts etc welcome.
      One interesting thing is that instances of both classes return Set for obj.class()
      (Not sure if this is desired.)
      set_fix.rb
      #  File    ;  "set_fix.rb"
      #  Version ;  0.3.2
      #  Date    ;  2014-03-01
      #  Author  ;  Dan Rathbun, Palm Bay, FL, USA
      if defined?(Sketchup)
      unless defined?(Sketchup;;Set)
        begin
          # Move the API's Set class into the Sketchup module namespace;
          Sketchup;;Set = Object.class_eval('remove_const(;Set)')
          # Paths to standard Ruby libs must first be pushed into
          # the $LOAD_PATH (aka $;,) array;
          if RUBY_PLATFORM =~ /(darwin)/ # Mac / OSX
            # require some other script that pushes Ruby lib paths into $;
          else # MS Windows
            ['C;/Ruby186/lib/ruby/1.8',
            'C;/Ruby186/lib/ruby/1.8/i386-mswin32'].each do |lib|
              $; << lib unless ($;.include?(lib) || $;.include?(lib.downcase))
          $;.uniq! # remove duplicate entries
          # Now require the standard Ruby Set class via 'set.rb'
          require('set')
        rescue LoadError
          Set = Sketchup;;Set
          raise
        else
          # No errors occured, so make Ruby's Set class have
          # the two methods, that the Sketchup;;Set class has;
          Set.class_eval('alias_method(;contains?,;include?)')
          Set.class_eval %q{
            def insert(*args)
              errors = {}
              args.each_with_index{|a,i|
                begin
                  add(a)
                rescue Exception => e
                  errors[i]= e
              unless errors.empty?
                stack = caller(0)
                called_from =( stack.size>1 ? stack[1] ; stack[0] )
                msg = "#{errors.size} errors occured during Set.insert() from #{called_from};\n"
                errors.each {|i,e|
                  msg<< "arg #{i} (#{args[i].class.name}); #<#{e.class.name}; #{e.message}>\n"
                raise(RuntimeError,msg)
            end # def insert()
      end # unless Sketchup;;Set class is defined.
      end # if Sketchup namespace is defined
      EDIT:
      0.1.0 : first post.
      0.2.0 : Added a class alias in the rescue block, to alias a toplevel Set constant, if the "set.rb" file cannot be found.
      0.3.0 : Changed the insert method from a simple alias of add, to an iteration that can handle multiple arguments like the API insert method can.
      0.3.1 : $0 returns a String, so comparison must be: $0 == 'SketchUp' (The Argument was not quoted.)
      0.3.2 : In Ruby 2.0 under SketchUp 2014, $0 returns a "-e", instead of "SketchUp" so that test was removed. We now just test for the Sketchup module namespace.
      The SketchUp API v14 moves the API Set class into the Sketchup namespace so it does not conflict with the Ruby standard library Set class.
      I'm not here much anymore.
      • Dan RathbunD
        Dan Rathbun
        EDIT: Added a class alias in the rescue block, to alias a toplevel Set constant, if the "set.rb" file cannot be found.
        Now 1 issue is that this script can only run once, as it is now.
        Thoughts ??
        • thomthomT
          Is the Ruby Set class compatible to override the SketchUp Set class?
          if RUBY_PLATFORM =~ /(darwin/ # Mac / OSX
          Isn't that regex invalid?
          • Dan RathbunD
            Dan Rathbun
            Yup fixed it.. thanx.
            • Dan RathbunD
              Dan Rathbun
              If the two method aliases for insert (for add,) and contains? (for include?,) are added to the Ruby Set class.
              The Ruby Set class has all of the other (and there is not that many,) methods of the API class.
              In addition the Ruby class has Enumerable mixed in, so it's so much more robust.
              The main difference would be speed. The API class is actually an exposure of a C++ collection.
              The Ruby class is actually a custom wrapper of a Ruby Hash. So most methods called, will in turn call some instance method on the internal @hash object.
              It also adds a subclass SortedSet and there is another RestrictedSet but it is commented out, for what reason, I do not know.
              • Dan RathbunD
                Dan Rathbun
                Update to v0.3.0
                • Dan RathbunD
                  Dan Rathbun
                  Update to v0.3.1
                  • Dan RathbunD
                    Dan Rathbun
                    Update to 0.3.2
                    • tt_suT
                      tt_su
                      I would recommend using the Standard Library Set class over the one in SketchUp if you can. It's better features and much faster.
                      We might be deprecating the Sketchup::Set class eventually. With the standard lib it doesn't make any sense for anything other than backward compatibility.
