    [Solved] Materials to Layers [by sdmitch]
    5 Posts 2 Posters 450 Views 2 Watching
    • U Offline
      unclex
      thanks for all authors
      but I cannot find a plugins like this:
      object with material "A" could be moved Layer "A",if this Layer isn't exist, could be generated automaticly.
      • sdmitchS Offline
        sdmitch
        All faces and surfaces have a front and a back and each can have a different material. Are you only concerned by materials applied to the front only, back only, or both front and back?
        http://sdmitch.blogspot.com/
        • U Offline
          unclex
          Front:)
          • sdmitchS Offline
            sdmitch
            @unclex said:
            Front:)
            Be aware that when you draw a rectangle on the xy plane, it is created face/front down. If you actually go beneath the face and paint it then pushpull it into a "solid", the material gets "flipped" to the back or inside. This plugin moves the edges of the face to the layer as well. It works on either the selection or the entire model if nothing is pre-selected.
            Create a layer for each material and move the face to it.
            • U Offline
              unclex
              Thanks A LOT
              i got, and it's what i want:)
