    [Plugin] scaleGroupFloat_dj Ver 1.6.5 Feb 15, 2013
    22 Posts 4 Posters 22.9k Views 4 Watching
    • dukejazzD
      dukejazz
      Copyright Feb 15, 2013
      DukeJazz: by James Cochran
      Best high precision 3D scale and move tool yet.
      With Features:
      ScaleGroupMove (re-sizes, scales, moves and set units) non cumulative
      CumulativeScaler (steps, moves, scale and rotates) cumulative 3D offset dolling
      Save location of a c-point (save target)
      Move to a save location c-point (move to target)(move and size to target)(move to object vector corner) (a line to object -at origin axis)
      Readout (Size,c-points, SF)
      boxPoint-drops small boxes as points (w,d,h)
      undoTool (resets, undos and redos)
      Gives fast alignment, of any local axes to origin axes
      Makes 3d shell thickness to any object.
      Draws vector and cpoint points of any group objects.
      Flatten objects in any directions
      With cumulativeScaler_dj you can step thing to make Spiral stairs , stairs cases
      Scale:
      Group Float Scaling tool scale objects, along XYZ axes.
      Drop down menu's for quick and easy use of X, Y, Z, XYZ
      Scale factor:
      Group object units range 1.0e-16 to 10e+16 m by ruby float
      Object Scale factor unit to 1.0e-99 to 1.0e+99 m
      Bounding Box meathod:[magnitude of length]
      You can enter or read the magnitude values a group object
      New read out: Format is now standard: magnitude unit
      You can copy and pin information to document
      Ratio factor to a standard scale factor
      Readout
      Size format = [magnitude of length] [Unit]
      center points =(x,y,z)
      SF = value ratio
      Units: (Imperial units and International metric units.)
      ["thou|in|ft|cubit|yd|rod|furlong|mi|Ym|Zm|Em|Pm|Tm|Gm|Mm|km|hm|dam|
      m|dm|cm|mm|um|nm|Angstrom|pm|am|fm|zm|ym|x?|quintillionth|y?|planckto"]
      scaleGroupFloat tool re-sizes to a group object SF scale or enter units.
      Sketchup scale tool re-sizes to a open model scale units.
      If you set SF=1, scaleGroupFloat units to Sketchup units respectively then is gives higher precision then sketchup model will do.
      Vector center:
      This will moves the group object to [x.y,z]
      Extended options:
      ["Show Bbox,Center,SF|Show Bbox,Center|Show Bbox|Show Center|Show SF|ShowBlank|Small format|Large format|no read format|no|Long read out|SnapLowPrecision|SnapHighPrecision|Draw vector|Draw cpoint|no|Move to target1|Move to target1 corner|Size as target1|Move and size to target1 |Save target1|Line up to target1 Red w-side|Line up to target1 Green d-side|Line up to target1 Blue h-side|no|Move to target2|Move to target2 corner|Size as target2|Move and size to target2 |Save target2|Line up to target2 Red w-side|Line up to target2 Green d-side|Line up to target2 Blue h-side|no|scale_dj|move_dj|resize_dj|cumulativeScaler_dj|keyboardScaleGroupFloat_dj|extended_options_dj|scaleMoveResize_dj"]#
      Bbox,Center,SF pins values to a object such as dimension w_d_h, center x_y_z and scale factor,
      Order of process:
      1. scale, units, magnitude and move read out is non sequentially cycle and can be cycle any time together.
      Freely use, and abuse at your own risk. Fitness of usage is not warranty implied.
      Only one Warning:
      Do not fully bomb or explode groups objects below 1.0e-o4 in size, the objects will disappear. to recover hit undo to make a groups object to reappear in the outliner.
      Thank you, have fun.
      History:
      Feb 15, 2013; scaleGroupFloat_dj v1.6.5
      -add cumulativeScaler_dj rotation around
      Feb 4, 2013; scaleGroupFloat_dj v1.6 bata
      -add cumulativeScaler_dj move around (a step boxpoint)
      -add cumulativeScaler_dj size linear stepper
      -add cumulativeScaler_dj move linear stepper
      -fixes
      v1.0 May 11
      -release
      Download:
      Feb 15 2013 v1.6.5
      scaleGroupFloat_dj v1.6.5.zip
      • dukejazzD
        dukejazz
        Update:
        v1.01 May 14
        -fix the inial inch magnitude reading in ft
        -fix the the snapping precision mode requirements
        • W
          watkins
          Just thought I write and say thank you for all your hard work. I cannot see an immediate use for your plugin, but I'm sure that it will be useful to many. What prompted you to write the plugin in the first place?
          Regards,
          Bob
          • dukejazzD
            dukejazz
            Update
            Re: [Plugin] scaleGroupFloat_dj Ver 1.1
            v1.01 May 27
            -fix move iteration problem
            -added a switch to group listing
            -add group dimension read out
            -reconfig doccuments and read outs
            • fix unts control system
            • dukejazzD
              dukejazz
              I found this problem by nickchun
              Stuck already!
              by nickchun on Thu May 17, 2012 7:35 am
              I have just started to build a DC for a cupboard which seems to have gone well until I tried to add some component options. I added the option to change the width of the cupboard but the units do not add up. The width should be 700mm but the actual size is coming out at 201.7mm? LenY and LenZ are also wrong.
              I can't make any sense of the sizes in terms of any possible metric to imperial conversions.
              Can anyone help?
              I used the calulator for finding scale factor ratio.... then I resized his cupboard.... then I was done
              • dukejazzD
                dukejazz
                Here's an immediate uses condiction
                The easiest way to say this:
                If your are a Manufacture Engineer and a customer came to you with a part block that measured 0.024 in size and is mil to 10000 of a in. and he tell you that he want the same standards to the part your going to make him. And he want you to do this on the fly... and your are new to this company... and not trained to use their cad system... and your job will be on the line. You need to fine the points centers to set up the laser to cut the tool out. So you reach the easy to use google sketchup and it can't help either...because the block dimension are to small...to the fining of laser block centers Help! well who need this job any way.
                Results:
                Google sketchup way 0.024000 - sad, no job
                Plugin scaleGroupFloat way 0.02400001 *1.0_in - happiness, job done, no job lost
                Now the resons why I wrote this scaleGroupFloat 3d scale resizer:
                After reading some one hundred fifthy reseason on why Sketchup is Inacurrate???
                I dicided to fix some of them
                Inacurrate???
                by seasdes on Thu Mar 22, 2012 11:48 pm
                "There are posts scattered post throughout the net stating that Sketchup is innacurate. Is there substance in this claim or are they talking through their ear**?"
                Other reasons
                -basic principles of surveying,
                -mashtab 4: reads things ok but unable to resize to small units
                -Is there any hope of making something visually noticeable about terrains or is it just too flat to to see
                • dukejazzD
                  dukejazz
                  A [x,y,z] mover;
                  Group Entity Translational moves can move to origin or any other [x,y,z] vector location
                  How its done in one simple steps.
                  • select, Enter x_y_z axes points and hit Enter
                  You shold be able to move anything, anywhere, very easily. πŸ‘
                  • dukejazzD
                    dukejazz
                    What can you do with this.
                    Scale and move group 3d entities:
                    A Example:
                    I download two things from google warehouse
                    A boy with his toy,
                    And a full size car
                    I rescaled the car and moved its [x,y,z]
                    Now I have a boy with his toys
                    Anything large can be made smaller to a size of a atom, or a atom resized to a moon.
                    • dukejazzD
                      dukejazz
                      Download:
                      Ver 1.2 June 4 2012
                      -release
                      • dukejazzD
                        dukejazz
                        Hi I working on a new Ver 1.2
                        The Bata
                        Ver 1.2 bata 2
                        is release on June 2
                        -fix the intanglement issue to scale and move.
                        -easy menu to use to pin dimension to document.
                        -added more Extended read out:
                        -B-box,Center,Ratio
                        -B-box,Center
                        -B-box
                        -Center
                        -Ratio
                        -draw vector
                        -rename boxes
                        -given a xyz make a point +
                        WIP
                        -given a xyz delete a text note
                        bata had 37 downloads
                        • dukejazzD
                          dukejazz
                          I made a small change in the zip file; the scaleGroupFloat_dj.rb was hidden
                          It will now load up at startup. The new ver is scaleGroupFloat_dj v1.2.0.zip
                          • dukejazzD
                            dukejazz
                            new update
                            Ver 1.3.0 2012, July 23
                            -add many more obtions to Extended mode:13ea
                            -add a repeat cycle
                            -fix the interaction of the scale and move
                            -less work to targeting and moveing objects
                            -higher perscion viewing e-07 to e-08
                            -moved scaleGroupFloat_dj.rb to dj_plugins folder
                            • dukejazzD
                              dukejazz
                              scaleGroupFloat_dj Ver 1.3
                              No rendering, everything is done in sketchup.
                              Quick work adding color to objects in your model
                              nosie, shine, color with transparency = mix block of glowing colors of light.
                              Extened options
                              Work the color blocks
                              save one as target
                              then the others use size and move to target.
                              πŸ’­ each object can have its own light show. wow!
                              • pep75P
                                pep75
                                WOW!
                                • dukejazzD
                                  dukejazz
                                  This is a importance new release of scaleGroupFloat_dj and its not a beta
                                  This ver is 1.5,3 Dec 11, 2012
                                  list=[,"Group scaling tool for objects, scales along XYZ axes.|
                                  Drop down menu's for quick and easy use of X, Y, Z, XYZ|
                                  Scale factor for oversize or undersize objects|
                                  Group move tool for objects|
                                  Group resize tool for objects|
                                  Cumulative dolling|
                                  Local and orgin axes mode|
                                  Muli inputbox mode for easy to view|
                                  Converts units|
                                  2 box readouts and 2 drawing readouts (small and large) |
                                  show a vector between local and orgin axes|
                                  shows a center points of sected object|
                                  extened option|
                                  2 levels of target saves|
                                  2 levels of target move to center of object|
                                  2 levels of target move and size|
                                  2 levels of target resize to objects|
                                  2 levels of line up side to axes|
                                  2 levels to move to corner of a object|
                                  Lots of readout formats|
                                  drawBoxPoint_dj to set up target moves inside and outside of objects|
                                  repeatUndoTool_dj to move through the undo's|
                                  Two target tool buttons for move and save|
                                  It's gives high precision float values"]
                                  • pep75P
                                    pep75
                                    Great!
                                    • dukejazzD
                                      dukejazz
                                      Update:
                                      Feb 15, 2013; scaleGroupFloat_dj v1.6.5 bata
                                      -add cumulativeScaler_dj size lenear stepper
                                      -add cumulativeScaler_dj move lenear stepper
                                      -fixes
                                      • dukejazzD
                                        dukejazz
                                        cumulativeScaler_dj
                                        with cumulativeScaler_dj you can step thing to make stairs
                                        To rotate about a edge step I used a bounding small box boxPoint by rotating upward 15x
                                        then move a step group into bouning box set
                                        • dukejazzD
                                          dukejazz
                                          Fast alinement of any local axes to the orgin axes
                                          Here is a fast rotation trick for a rotated component or a group
                                          meathod: target save and target move
                                          step 1: Make one component unique.( right click context list for making component unique )
                                          step 2: Press 1-time left click, the component you want to change. Save target, via scaleGroupFloat_dj (then press ok).
                                          step 3: Press 2-times with left button this will set axes to the component and 3-times more will edit the selection of the object. Using the Move to target toolbar, via scaleGroupFloat_dj.(now press ok) This will auto aline component to orgin plain. Now select ouside of component area, now your done.
                                          All above steps is shown here
                                          Also with the axes tool you can aline any local axes side to the orgin axes
                                          • dukejazzD
                                            dukejazz
                                            Update:
                                            Jan 13 2013 scaleGroupFloat_dj v1.5.5
                                            • expanded cumulativeScaler_dj (now dose xyz x y z scale,step move, step size and rotation)
                                              new
                                            ...add thickness to objects
                                            ...dolling objects
                                            • fix a better error trap
                                            -added update a repeat move to target auto mode
                                            (frist pass input box then more pressing the button go to auto mode repeat)
                                            green target
                                            -added update a repeat readout target auto mode
                                            white target
                                            -added update use save to target to unfreeze the repeat auto modes
                                            ( this also will fix scaleGroupFloat_dj and cumulativeScaler_dj lock out by auto mode repeat)
                                            red target
                                            • added rescale to a very small one demcision (any direction local object) will be flatten to outline wire when you group explode you can then resurface by putting a line accross the retangle.
                                            • added the dropping of a boxPoint to a 1d line or a 2d object to make 3d groups for resizing in on the orgin axes
                                            5
                                            • added the uses of the axes tool (right click move) to rotate objects by steps of orgin
                                              (works with scaleGroupFloat_dj and cumulativeScaler_dj
                                            • 1 / 2
