    [Plugin] scaleGroupFloat_dj Ver 1.6.5 Feb 15, 2013
    22 Posts 4 Posters 23.0k Views 4 Watching
    • dukejazzD
      dukejazz
      Update:
      v1.01 May 14
      -fix the inial inch magnitude reading in ft
      -fix the the snapping precision mode requirements
      • W
        watkins
        Just thought I write and say thank you for all your hard work. I cannot see an immediate use for your plugin, but I'm sure that it will be useful to many. What prompted you to write the plugin in the first place?
        Regards,
        Bob
        • dukejazzD
          dukejazz
          Update
          Re: [Plugin] scaleGroupFloat_dj Ver 1.1
          v1.01 May 27
          -fix move iteration problem
          -added a switch to group listing
          -add group dimension read out
          -reconfig doccuments and read outs
          • fix unts control system
          • dukejazzD
            dukejazz
            I found this problem by nickchun
            Stuck already!
            by nickchun on Thu May 17, 2012 7:35 am
            I have just started to build a DC for a cupboard which seems to have gone well until I tried to add some component options. I added the option to change the width of the cupboard but the units do not add up. The width should be 700mm but the actual size is coming out at 201.7mm? LenY and LenZ are also wrong.
            I can't make any sense of the sizes in terms of any possible metric to imperial conversions.
            Can anyone help?
            I used the calulator for finding scale factor ratio.... then I resized his cupboard.... then I was done
            • dukejazzD
              dukejazz
              Here's an immediate uses condiction
              The easiest way to say this:
              If your are a Manufacture Engineer and a customer came to you with a part block that measured 0.024 in size and is mil to 10000 of a in. and he tell you that he want the same standards to the part your going to make him. And he want you to do this on the fly... and your are new to this company... and not trained to use their cad system... and your job will be on the line. You need to fine the points centers to set up the laser to cut the tool out. So you reach the easy to use google sketchup and it can't help either...because the block dimension are to small...to the fining of laser block centers Help! well who need this job any way.
              Results:
              Google sketchup way 0.024000 - sad, no job
              Plugin scaleGroupFloat way 0.02400001 *1.0_in - happiness, job done, no job lost
              Now the resons why I wrote this scaleGroupFloat 3d scale resizer:
              After reading some one hundred fifthy reseason on why Sketchup is Inacurrate???
              I dicided to fix some of them
              Inacurrate???
              by seasdes on Thu Mar 22, 2012 11:48 pm
              "There are posts scattered post throughout the net stating that Sketchup is innacurate. Is there substance in this claim or are they talking through their ear**?"
              Other reasons
              -basic principles of surveying,
              -mashtab 4: reads things ok but unable to resize to small units
              -Is there any hope of making something visually noticeable about terrains or is it just too flat to to see
              • dukejazzD
                dukejazz
                A [x,y,z] mover;
                Group Entity Translational moves can move to origin or any other [x,y,z] vector location
                How its done in one simple steps.
                • select, Enter x_y_z axes points and hit Enter
                You shold be able to move anything, anywhere, very easily. πŸ‘
                • dukejazzD
                  dukejazz
                  What can you do with this.
                  Scale and move group 3d entities:
                  A Example:
                  I download two things from google warehouse
                  A boy with his toy,
                  And a full size car
                  I rescaled the car and moved its [x,y,z]
                  Now I have a boy with his toys
                  Anything large can be made smaller to a size of a atom, or a atom resized to a moon.
                  • dukejazzD
                    dukejazz
                    Download:
                    Ver 1.2 June 4 2012
                    -release
                    • dukejazzD
                      dukejazz
                      Hi I working on a new Ver 1.2
                      The Bata
                      Ver 1.2 bata 2
                      is release on June 2
                      -fix the intanglement issue to scale and move.
                      -easy menu to use to pin dimension to document.
                      -added more Extended read out:
                      -B-box,Center,Ratio
                      -B-box,Center
                      -B-box
                      -Center
                      -Ratio
                      -draw vector
                      -rename boxes
                      -given a xyz make a point +
                      WIP
                      -given a xyz delete a text note
                      bata had 37 downloads
                      • dukejazzD
                        dukejazz
                        I made a small change in the zip file; the scaleGroupFloat_dj.rb was hidden
                        It will now load up at startup. The new ver is scaleGroupFloat_dj v1.2.0.zip
                        • dukejazzD
                          dukejazz
                          new update
                          Ver 1.3.0 2012, July 23
                          -add many more obtions to Extended mode:13ea
                          -add a repeat cycle
                          -fix the interaction of the scale and move
                          -less work to targeting and moveing objects
                          -higher perscion viewing e-07 to e-08
                          -moved scaleGroupFloat_dj.rb to dj_plugins folder
                          • dukejazzD
                            dukejazz
                            scaleGroupFloat_dj Ver 1.3
                            No rendering, everything is done in sketchup.
                            Quick work adding color to objects in your model
                            nosie, shine, color with transparency = mix block of glowing colors of light.
                            Extened options
                            Work the color blocks
                            save one as target
                            then the others use size and move to target.
                            πŸ’­ each object can have its own light show. wow!
                            • pep75P
                              pep75
                              WOW!
                              • dukejazzD
                                dukejazz
                                This is a importance new release of scaleGroupFloat_dj and its not a beta
                                This ver is 1.5,3 Dec 11, 2012
                                list=[,"Group scaling tool for objects, scales along XYZ axes.|
                                Drop down menu's for quick and easy use of X, Y, Z, XYZ|
                                Scale factor for oversize or undersize objects|
                                Group move tool for objects|
                                Group resize tool for objects|
                                Cumulative dolling|
                                Local and orgin axes mode|
                                Muli inputbox mode for easy to view|
                                Converts units|
                                2 box readouts and 2 drawing readouts (small and large) |
                                show a vector between local and orgin axes|
                                shows a center points of sected object|
                                extened option|
                                2 levels of target saves|
                                2 levels of target move to center of object|
                                2 levels of target move and size|
                                2 levels of target resize to objects|
                                2 levels of line up side to axes|
                                2 levels to move to corner of a object|
                                Lots of readout formats|
                                drawBoxPoint_dj to set up target moves inside and outside of objects|
                                repeatUndoTool_dj to move through the undo's|
                                Two target tool buttons for move and save|
                                It's gives high precision float values"]
                                • pep75P
                                  pep75
                                  Great!
                                  • dukejazzD
                                    dukejazz
                                    Update:
                                    Feb 15, 2013; scaleGroupFloat_dj v1.6.5 bata
                                    -add cumulativeScaler_dj rotation around
                                    Feb 4, 2013; scaleGroupFloat_dj v1.6 bata
                                    -add cumulativeScaler_dj move around (a step boxpoint)
                                    -add cumulativeScaler_dj size lenear stepper
                                    -add cumulativeScaler_dj move lenear stepper
                                    -fixes
                                    • dukejazzD
                                      dukejazz
                                      cumulativeScaler_dj
                                      with cumulativeScaler_dj you can step thing to make stairs
                                      To rotate about a edge step I used a bounding small box boxPoint by rotating upward 15x
                                      then move a step group into bouning box set
                                      • dukejazzD
                                        dukejazz
                                        Fast alinement of any local axes to the orgin axes
                                        Here is a fast rotation trick for a rotated component or a group
                                        meathod: target save and target move
                                        step 1: Make one component unique.( right click context list for making component unique )
                                        step 2: Press 1-time left click, the component you want to change. Save target, via scaleGroupFloat_dj (then press ok).
                                        step 3: Press 2-times with left button this will set axes to the component and 3-times more will edit the selection of the object. Using the Move to target toolbar, via scaleGroupFloat_dj.(now press ok) This will auto aline component to orgin plain. Now select ouside of component area, now your done.
                                        All above steps is shown here
                                        Also with the axes tool you can aline any local axes side to the orgin axes
                                        • dukejazzD
                                          dukejazz
                                          Update:
                                          Jan 13 2013 scaleGroupFloat_dj v1.5.5
                                          • expanded cumulativeScaler_dj (now dose xyz x y z scale,step move, step size and rotation)
                                            new
                                          ...add thickness to objects
                                          ...dolling objects
                                          • fix a better error trap
                                          -added update a repeat move to target auto mode
                                          (frist pass input box then more pressing the button go to auto mode repeat)
                                          green target
                                          -added update a repeat readout target auto mode
                                          white target
                                          -added update use save to target to unfreeze the repeat auto modes
                                          ( this also will fix scaleGroupFloat_dj and cumulativeScaler_dj lock out by auto mode repeat)
                                          red target
                                          • added rescale to a very small one demcision (any direction local object) will be flatten to outline wire when you group explode you can then resurface by putting a line accross the retangle.
                                          • added the dropping of a boxPoint to a 1d line or a 2d object to make 3d groups for resizing in on the orgin axes
                                          5
                                          • added the uses of the axes tool (right click move) to rotate objects by steps of orgin
                                            (works with scaleGroupFloat_dj and cumulativeScaler_dj
                                            maxvector9
                                            There is no download link. Where can I download it or is it still in a test fase?
