    Ruby .rb files in Explorer Preview Pane
    6 Posts 3 Posters 1.8k Views 3 Watching
      Jim
      Here's a little util to set plain text files (such as .rb files) to show in Windows Explorer Preview Pane.
      http://www.winhelponline.com/blog/make-the-preview-pane-in-vista-to-display-contents-of-text-based-files/
      (FYI: The preview pane can be toggled using Alt-P)
      • Dan RathbunD Offline
        Dan Rathbun
        A Windows 6+ utility only, it seems.
        I'm not here much anymore.
        • jeff hammondJ Offline
          jeff hammond
          should i drop the 'you should see how this works on osx' bomb ? or should i just keep my mouth shut? πŸ’š
          dotdotdot
            Dan Rathbun
            We do not need a platform flame war.. thank you anyway. πŸ˜›
              Jim
              I was a die-hard Debian/GNU Linux user since about 1996, but switched to Windows just to be able to run SketchUp in a native environment. This was the year SketchUp was bought by Google and we all discovered the Free version. I don't really miss much about Linux, though.
              My view on computers has changed since then, though. Then, I saw it as a challenge when software broke. Now, I just want the damned things to work so I can get my work done.
                Jim
                Well, this is one of those no-brainers that should "just work" IMO. Ideally, when I select ay plain text file, it should be shown in the preview pane, plus there should be a toggle button to enter/exit "edit" mode in the preview pane.
                This is how I would spec it if that were my job.
