    Context Menu Question
    3 Posts 2 Posters 225 Views 2 Watching
    • K Offline
      ktkoh
      For a context menu could I determine that the selection is a component within a parent component? I found the enity parent but can't figure out how determine that the parent is a component.
      Thanks Keith
      • Dan RathbunD Offline
        Dan Rathbun
        require('sketchup.rb')
        module K2K;;SomePlugin
          COMMAND_NAME = "Nested Component Command Title Here"
          class << self
            def nested_component_command(obj)
              # command code here
          end # proxy class
          ### RUN ONCE
          unless file_loaded?(File.basename(__FILE__))
            ### CONTEXT MENU HANDLER
            UI.add_context_menu_handler do |popup|
              sel = Sketchup.active_model.selection
              unless sel.empty?
                if sel.single_object?
                  obj = sel[0]
                  if obj.is_a?(Sketchup;;ComponentInstance) &&
                  obj.parent.is_a?(Sketchup;;ComponentDefinition)
                    popup.add_item(COMMAND_NAME) {
                  end # component test
                end # single_object?
              end # unless empty?
            end # add_context_menu_handler
            file_loaded(File.basename(__FILE__))
          end # RUN ONCE
        end # module
        I'm not here much anymore.
        • K Offline
          ktkoh
          Thanks Dan that worked and was just what I needed.
          Keith
