3 AxisThermwood CNC router miter cuts
Edit Note: I need to update this file to reflect some improvements. It is important to note that the ball end mill miter passes cut shy by about 15-20 thousandths to preserve the vacuum table hold on the small parts I often cut.
Original post:
I just posted something (I think) useful on the SketchUp 3-D warehouse for use with most Thermwood CNC routers. It is the layer convention names necessary to cut miter angles on a 3 Axis router by directly importing the dxf drawing from SketchUp Pro to the CNC machine. This eliminates the need to use either Profile Modeler, Solidworks or MasterCam (all great programs, but two less links in the CAD/CAD/CAM/CNC chain). To bring a mitered cut part from Sketchup to the machine it now takes 3-4 steps per edge rather than having to redraw the entire part and additional steps per edge. The Thermwood CNC machines have built-in control nesting software that allows direct DXF imports. I don't know what other CNC routers have this capability. The cutting depths and positions are based off of a large excel file that I will latter extract the equations to make a plug-in specifically for use with the Thermwood routers.
http://sketchup.google.com/3dwarehouse/details?mid=2258e73b3416beb5ed5c9291237154c3&prevstart=0
Once I rewrite the equations I could use some help with the plugin. -
Glad to see a fellow THM user interested in sketch up. I was wandering if something tike this was possible good luck with your plugin. I use it often for complicated geometry and mdf glass doors. The biggest problem I run into is that Sketch up's circles and arcs are all line segments. And for that reason I have not ben able to use the drill command I have to use pocket instead.Allso outlines or centerlines on large arcs or circles tend to be jittery unless the number of segments are increased .I for one would like to see a plugin for mdf doors.
Hey Scott M
Sorry I just saw you post from 2010.To do a dxf drawing to the Thermwood machine follow the following rules:
-Use sketchUp Pro
-raw circles as drawn export as true circles in a dxf so long as they are not grouped under a layer name active on the thermwood, and not scaled or otherwise tweeked or exploded.
-Drill layer naming convention "drill z0p250" drills a 0.250 deep hole using a 1/4" dia mill bit, or if you only have a 1/8" diameter bit, it will use it so long as in the tool menue in control nesting the bit is permitted to interpolate that large a diameter. -
I just updated this file to include all miter angle cuts between 30 degrees and 166 degrees.
The new link is below:
http://sketchup.google.com/3dwarehouse/details?mid=4984de825c7932eb73ac8f193878e4bc&prevstart=0Description of downloadable file:
This model contains multiple layer names and lines representing the cut path of a 3/8" ball end mill along the edge of a part of thickness 0.499 inches. It allows carpentry joints at all angles between 30 and 166 (as measured through the acute angle of the matching faces) An example of the application is in the file and shows how to use the pre-grouped angle patterns. The angle patterns show their z azis placement. Steps: 1 measure part angle, 2 select angle, 3 move and place as shown in example, 4 stretch the grouped miter angle pattern so it goes slightly ( 1/2" diameter of 3/8" bit) of part. The layer name convention is directly compatible with Thermwood Control Nesting Software driven machines with 0.375 being end mill and 0.374 being ball end mill in tool setup. The angle patterns are grouped and inter-related through the sketchup component feature (change one line name, and all other cut paths for all other angles auto-update) There is an additional 3/8" end mill clean up pass for steep angle miters greater than 102 degrees. The drawing of the ball end mill and end mill bit was done by others (as noted).
Register LoginAdvertisement
