    HELP with Sketchup Hypernurbs? soften corners?
    24 Posts 8 Posters 3.0k Views 8 Watching
      Roger
      jpg
      A little rough but you get the idea
      turn on hidden line
      http://www.azcreative.com
        mspisz
        Thanks for that Roger πŸ˜„ but its a bit inconvenient for me. I could do the wheel your way but again a lot of other parts of the tank wont work with that technique... I know it will look a bit dodgy on bigger parts.
          Anthony R
          I had a little play with your problem and found that if I extended the cut out arc a little the round corners plugin worked better and looked more like what I think your after. I'm all ways trying to get smooth transitions through multiple surfaces and I often have to alter the angle of surfaces a bit first and return it after the tool works.
          pic
          • DesertRavenD Offline
            DesertRaven
            Try MOI, free trial and dirt cheep, clean modeling. http://moi3d.com/2.0/docs/tutorials.htm
            @anthony, did you do a solid check on this?
            simplicity is the ultimate sophistication
            • 2 / 2
