    Water Bottle
    25 Posts 12 Posters 5.1k Views 12 Watching
      leminilab
      @hieru said:
      The only part of the water that is separate is the top surface. That surface has one water material applied to it and the part of the bottle below the top surface has another material applied, which you have to assign a container material (in this case the plastic used for the rest of the bottle).
      There's a really useful diagram over on the Thea forum, but I can't find it at the moment.
      http://www.thearender.com/forum/viewtopic.php?f=54&t=5817&hilit=glass+liquid
      I don't know if you must be logged in first to read the post... πŸ˜•
      • "Live every day as if it were your last and then some day you'll be right."
      • "ThomThom rules!!!"
      • HieruH Offline
        Hieru
        Frederik's diagram on that thread is pretty good and Notareal provides some useful variations, but I thought all the options might be a bit confusing.
        www.davidhier.co.uk
          Roger
          Some Post Pro
          Just some post pro to see what you think. The DOF simulation and opening up the tones in the top of the bottle are the most important effects.
          http://www.azcreative.com
          • HieruH Offline
            Hieru
            Thanks for that Roger - I had completely overlooked the possibility of using a little DOF.
            www.davidhier.co.uk
            • N Offline
              notareal
              Keep in mind that the posted Frederik's diagram is for Kerkythea. Even as models needs to be split a bit similarly in Thea, same diagram does not apply. Use of "Container" is required for correct result. Study Thea example scene GlassOfWater.scn.thea (that you can find under File > Scenes > Examples). Also on said topic it's mentioned that you need to use mouse right click > Assign Interface. "Assign Interface" was replaced in some point with term "Assign Container".
              • 2 / 2
