    <=> to determine version newer or older?
    9 Posts 2 Posters 325 Views 2 Watching
      Say, you want to do a version check to detect if a given module is the required minimum and alert the user if it is not.
      Is this safe? Using and array with the version number and the <=> operator? Or is there some logic flaw here which might make the check fail?
      <span class="syntaxdefault">minimum </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault"> 1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0 </span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">version </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault"> 1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">20 </span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">if minimum </span><span class="syntaxkeyword"><=></span><span class="syntaxdefault"> version </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 1<br />  UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxstring">'Sad Panda ;('</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /></span>
      • Dan RathbunD Offline
        Dan Rathbun
        You cannot make numeric literals with more than 1 decimal point:
        min = 1.2.3 Error: #<SyntaxError: (eval): compile error (eval): no .<digit> floating literal anymore; put 0 before dot
        I'm not here much anymore.
          Dan Rathbun
          I think this is safest:
          module SomeLib
            VERSION = "1.2.3"
            VERSA   = VERSION.split('.').map{|i| i = i.to_i }
          begin
            require("SomePath/to/SomeLib.rb")
            if defined?(SomeLib)
              minver = [1,2,5]
              if minver < SomeLib;;VERSA
                msg = "This plugin requires SomeLib version #{minver.join('.')} or higher."
                msg<< "      \n\nCurrent installed SomeLib version is; #{SomeLib;;VERSION}\n"
                UI.messagebox(msg)
                exit(0)
          rescue Exception => e
            # catch SystemExit or LoadError here
          else
            # no errors, load the plugin;
            require("ThisPath/to/ThisPlugin.rb")
            My bad, I typed . instead of , when posting the example... 😳
              Dan Rathbun
              It is traditional in Ruby for VERSION constants to be a String of form "major.minor.teeny" (that should follow the RubyGems standard for use*****.)
              But comparing numeric strings can cause collating problems, so usually yes you make a array copy, using integer members (which is faster for comparison anyhow.)
              ***** The RubyGems standard for version number use:
              major = change in Compatibility
              minor = change in Functionality, but not Compatibility
              teeny = no change in intended Functionality, or Compatibility
              (ie.. bug fix, typo fix, documentation fix, etc.)
                But given the example in my OP, <=> does seem to return correct value indicating "newer" or "older". From my tests it seemed to work fine...
                  Dan Rathbun
                  Of course it does.. it HAS to. <, >, >= etc (for classes that mix in Comparable,) will not work, unless <=> is first defined.
                  But there is subtle issue here. That is that the members of your array are Integer class, which are immediate objects.
                  It may be a different story if the members of the array were non-immediate strings with numerical characters.
                    Dan Rathbun
                    I suppose it does not matter speedwise..
                    if minimum <=> version == 1
                    is actually doing an extra unneeded method call, than:
                    unless version >= minimum
                      Oh, that works as well...
                      And I've been comparing each value by itself when putting it all in an array works just as easy...
