    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Podium exterior
    29 Posts 10 Posters 6.0k Views 10 Watching
    • StinkieS Offline
      Stinkie
      Not the best exterior ever -I am no Bertrand Benoit- but I enjoyed doing this.
      • andybotA Offline
        andybot
        Nice feel to it. I like the soft lighting you have going on. I've been impressed with your Podium renders. I tried the plugin a couple years ago and it was rather lousy then. Looks like it's come quite a ways. But you're right - you're not Bertrand - none of us are... ๐Ÿ˜ฎ
        • RichardR Offline
          Richard
          WOW dude, that's great! The grass is brilliant, did you chop that in or in scene and the volume lighting right is that photochopped post pro? Nice mate! Just the trees and panels look to give it away!
          BUILTBRAND.COM.AU
          • StinkieS Offline
            Stinkie
            Yeah, I photoshopped this pretty intensely. The trees aren't great, agreed. I really ought to do those in PS. Anyone know a good tut on compositing?
            • cheddaC Offline
              chedda
              Looks good Tom is the building & site fictional ? Only because i think these idyllic forest/garden scenes are a little misleading sometimes.
              Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
              • RichardR Offline
                Richard
                Mate I think DavidH has done some on in the resources section, he's a bit of a master! When it comes to compositing I know I SUCK BIG - hence why I've modelled up some plants to make up for it!
                BUILTBRAND.COM.AU
                • michaliszissiouM Offline
                  michaliszissiou
                  Brilliant ๐Ÿ‘
                  I feel your pain with these trees.
                  I tried to model some decent trees in blender but they're rather heavy for SU. Possible though, on your own risk LOL.
                  Trees have to be real 3d objects, separated leaves included. Let's face it.
                  Excellent work Tom.
                  My suggestion? Bring it all to blender, set the scene and render (cycles). Tig's obj exporter is EXCELLENT!!!
                  The new tree generator of blender is quite impressive.
                  Grass? Piece of cake - real 3d particles grass I mean.
                  • andybotA Offline
                    andybot
                    Tree[d] is also a great tool. If you make a good map of groups of leaves, you can get a decent poly count for SU by keeping the leaf count low.
                    • StinkieS Offline
                      Stinkie
                      Thanks, guys.
                      The site is fictional. The building I don't know -I based it on an Evermotion model.
                      I'd rather try this with Thea, I think -as soon as I find the time, that is. Not that I have anything against Blender, I'm just not comfortable with it yet.
                      And I'll certainly try this scene with Modo 601, as soon as the demo's out.
                      • RichardR Offline
                        Richard
                        Would love to see some blender trees )in another thread obviously) Michalis! I use ONYX which is a bit hard to get head around but it builds GREAT TREES!
                        BUILTBRAND.COM.AU
                        • pugz1983P Offline
                          pugz1983
                          Hi Everybody,
                          Like the render Tom. Some of the best work I've seen with Podium. I also struggled with the trees/grass and plants problem and SU, and after a long period of trail and error and a lot of bugsplats and a SU that freezes I......... decided that SU is just not suitable for this type of things. The way to go is a workflow with another main compositing 3D software pack like Blender, Cinema4D or 3DSMax. I do my modeling in SU as far as I can. Then I export my model and import into blender for example. Grass, trees and plants are easy to import into model now. You can use plugins to spread grass or use hair particle system to create grass. Blender and other programs can handle Xfrog, Onyx strees for example and when using instancing the size of models won't be a problem. The only thing that takes time is finding the right mix of apps in your workflow that best suite you and the type of work you do.
                          PS: I forgot to mention Vue. Vue is very capable for creating nature elements like trees, grass shrubs and plants.
                          Greetz Twan
                            michaliszissiou
                            The big problem with SU is that it can not import huge meshes. Huge? Not really, we're talking about >64k tri meshes. And trees need ~100-300K.
                            To split into groups isn't a very promising method either. More complicated than helpful.
                            Blender integrated tree generator is fine. There's also the excellent ngplants open source app.
                            http://yorik.uncreated.net/greenhouse.html
                            http://ngplant.sourceforge.net/#downloadanc
                            @Richard
                            Of course, but on what topic? It has nothing to do with SU .
                            BTW for 2d cutout lovers. Have you tried this?
                            http://arnaud.ile.nc/cantree/generator.php
                            • StinkieS Offline
                              Stinkie
                              You're right, obviously. Still, one cannot keep buying and learning new software. ๐Ÿ˜„
                              • DanielD Offline
                                Daniel
                                Beautiful image, Tom.
                                FYI, the building is real. It is called the Delta Shelter, and was designed by Tom Kundig of Olson Kundig Architects, and has been published numerous times. http://www.olsonkundigarchitects.com/Projects/38/Delta-Shelter
                                My avatar is an anachronism.
                                • StinkieS Offline
                                  Stinkie
                                  Thanks for the link. I quite like that building -I'd not mind living there.
                                  This picture is way prettier than my render:
                                  http://www.olsonkundigarchitects.com/gallery_cache/38/430_380/Delta-Shelter-TB-056.jpg
                                  • RichardR Offline
                                    Richard
                                    Yeah I'm like Tom - having to learn new apps is a pain for one and then adding new steps to workflow is another! Personally I'd like to take out steps from workflow!
                                    @Michalis - WOW mate, those Blender plants are THE BOMB! OMG! Start a thread in the corner bar, that's what it's for!
                                    @Tom - BTW mate, just noticed the reflections on the upper story right facing windows seems weird when you should be seeing reflected sky from such a low placed camera.
                                    I don't know if Podium supports Proxies, they help a bundle. These plants I created in SU although not high poly so I can spread them around, are still poly loaded enough to slow SU down if you turn their layer on before export. Proxies help by way of keeping one instance on a hidden layer and populating with a scaled proxy which then contributes very little load on SU!
                                    These days with FIRE for real time material, camera and light tweaking I've just about done away with Photoshop post pro excepting for background replacement, CYMK conversion, and image resizing. And as the pluin developer is currently rewriting the plugin to support xrefing of high poly MXS files for SU proxies on export I'll also be done with Maxwell Studio. Meaning ALL work will be direct from SU with limited PS post pro!
                                    BUILTBRAND.COM.AU
                                    • StinkieS Offline
                                      Stinkie
                                      Yeah. ๐Ÿ‘
                                      There's some really big trees in that garden, Richard!
                                      Nope. The app's pretty bare bones.
                                      • srxS Offline
                                        srx
                                        Great job. U can use Kerkythea xfrog trees library in Thea.
                                        www.saurus.rs
                                        • pugz1983P Offline
                                          pugz1983
                                          After find a way to use high poly plants and trees there's another challenge awaiting. How to figure out what plants and trees go together. When just throwing in a bunch of trees and plants won't make it look good. I'm always struggling with the way plants and trees grow and are arranged in an axterior scene. But I guess that it's just a case of studiyng the nature around you.
                                          Greetz Twan
                                          • StinkieS Offline
                                            Stinkie
                                            Or ... you could say "to hell with plants". ๐Ÿ˜‰ Indigo version:
                                            • 1 / 2
