    Looking for plugin:Component2Point of Intersection
    6 Posts 3 Posters 741 Views 3 Watching
    • Z Offline
      ZFRPS
      This plugin for BIM:
      sketchup is bim
      • guanjinG Offline
        guanjin
        dian.gif 😍
        I come from China, is to learn
        • Z Offline
          ZFRPS
          First,very thanks PILOU,
          your way is useful for me,Before no found this way;I long think a plugin:Components onto Faces by ChrisFullmer...maybe very difficult because have normal on faces and no have normal at points,no find normal at points , so components onto points no way.
          look forward to someone have better way to do it.
          Components onto Faces is great plugin,But...only onto faces....
          sketchup is bim
          • Z Offline
            ZFRPS
            小龙:
            谢谢你的GIF,非常棒!期待我们在这样的国际平台上展示我们对SU的挚爱,并且结交到更多的爱好者作为朋友,我的英语语法一塌糊涂,如果有些时候当你看见我的表达不正确的时候请多多指教!同时也请各位国内的老友多多支持!
        同样来自中国的ZF拜谢!
            sketchup is bim
            • guanjinG Offline
              guanjin
              小龙:
        同样来自中国的ZF拜谢!
              Great! Really want to thank http://forums.sketchucation.com this platform, thanks to their hard work and like Thomthom
                You can make that easily with the Marvelous Thomthom Guide Tools!
                Select all your lines : Guide Tools / CPoint (Construction Point) Edge-Edge
                so you have a CPoint at each intersection! 😎
                Select your Component + All your lines ( you are not obliged to selected only CPoints ! )
                Guid tools / Insert Components at Cpoints ☀
                So you have your result! 👍
                Select only Cpoint with the fabulous Selection Toys again by Thomthom: Kill them
                Of Course you will must Change orientation of your Components following general orientation of your lines !
                Or in your case maybe use 4 differents components (or more)depending of the project
                Or rotate some of them after a general ThomThom Guide Tools use if you want just one component
