    Text Export Doesn't Save
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    1 Posts 1 Posters 7.8k Views 1 Watching
    • J
      Jim57
      The past two times I've used Layout, I've laid out and dimensioned my model, then saved. As a last step I add text blocks and export as PDF. The text does not export.
      I can't say for sure if I've saved the text blocks. However, my fix is to click again on the text block and save, then re-eport. Both times the text has come through on the second try.
      Jim
