    Create new instance of a Ruby object in C?
    12 Posts 2 Posters 2.3k Views 2 Watching
      Say I want to create a Sketchup::Color object from a C Extension. How do you create that object? I thought to have read somewhere that it's not as easy as calling .new - is this correct? I can't seem to find the info now. Maybe I just imagined it...?
      • Dan RathbunD Offline
        Dan Rathbun
        You can cheat...
        VALUE tt_clr;
        tt_clr = rb_eval_string("Sketchup;;Color.new(0, 128, 255)");
        I'm not here much anymore.
          Wonder what the performance difference is.
          This is what I've found so far. (untested)
          <span class="syntaxdefault">struct Color<br /></span><span class="syntaxkeyword">{<br /></span><span class="syntaxdefault">  unsigned char red</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> green</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> blue</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> alpha</span><span class="syntaxkeyword">;<br />};<br /><br /></span><span class="syntaxdefault">static VALUE color_to_sketchup</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> struct Color color </span><span class="syntaxkeyword">)<br />{<br /></span><span class="syntaxdefault">  VALUE mSketchup</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> cColor</span><span class="syntaxkeyword">;<br /></span><span class="syntaxdefault">  VALUE skp_color</span><span class="syntaxkeyword">;<br /></span><span class="syntaxdefault">  VALUE red</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> green</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> blue</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> alpha</span><span class="syntaxkeyword">;<br /></span><span class="syntaxdefault">  VALUE args</span><span class="syntaxkeyword">;<br /></span><span class="syntaxdefault">  <br />  mSketchup </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> rb_define_module</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Sketchup"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  cColor </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> rb_define_class_under</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> mSketchup</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Color"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  <br />  red   </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> rb_float_new</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> color</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">red </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  green </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> rb_float_new</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> color</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">green </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  blue  </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> rb_float_new</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> color</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">blue </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  alpha </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> rb_float_new</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> color</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">alpha </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  <br />  args </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> rb_ary_new3</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> 4</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> red</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> green</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> blue</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> alpha </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  <br />  skp_color </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> rb_obj_alloc</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> cColor </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  rb_obj_call_init</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> skp_color</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> args</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 4 </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  <br />  return skp_color</span><span class="syntaxkeyword">;<br />}</span><span class="syntaxdefault"> </span>
          Is it possible to do static initialization of module and classes? Avoiding them being "defined" every time. Or is it maybe not an issue? Just wonder if it's possible to avoid more calls to Ruby.
          <span class="syntaxdefault"></span><span class="syntaxkeyword">static&nbsp;</span><span class="syntaxdefault">VALUE&nbsp;foobar</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">struct&nbsp;Color&nbsp;color&nbsp;</span><span class="syntaxkeyword">)<br />{<br />&nbsp;&nbsp;</span><span class="syntaxdefault">VALUE&nbsp;skp_color</span><span class="syntaxkeyword">;<br />&nbsp;&nbsp;</span><span class="syntaxdefault">VALUE&nbsp;red</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">green</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">blue</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">alpha</span><span class="syntaxkeyword">;<br />&nbsp;&nbsp;</span><span class="syntaxdefault">VALUE&nbsp;args</span><span class="syntaxkeyword">;<br />&nbsp;&nbsp;static&nbsp;</span><span class="syntaxdefault">VALUE&nbsp;mSketchup&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">rb_define_module</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxstring">"Sketchup"&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;static&nbsp;</span><span class="syntaxdefault">VALUE&nbsp;cColor&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">rb_define_class_under</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSketchup</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"Color"&nbsp;</span><span class="syntaxkeyword">);<br />}<br />&nbsp;</span><span class="syntaxdefault"></span>
            Dan Rathbun
            @thomthom said:
            Is it possible to do static initialization of module and classes? Avoiding them being "defined" every time. ...
            Probably (open the Ruby CHM reference, and go to Array::new(), then click on the definition to view the C source.)
            Also.. take another look at John H's example in THIS topic.
            That should tell you, Google is defining static interface's to API objects.
            The challenge is to know what are the identifiers that they define. (Keep in mind that, if you are running C code under the Sketchup process, (rather than in a separate 3rd party application,) everything you see defined in the SDKs for SKPwriter and SKPreader DLLs, are ALREADY loaded, as part of the executable code. (In other words, those DLLs are just a subset of the code, cut out into DLLs, with exported functions, for use with 3rd party applications, where it's expected that the Sketchup app is not running.)
              That is C++ though. It let you define variables anywhere in the scope. C requires you to define everything first before it's being used. Which is why I'm confused about static variables which seems to be able to define and set at the same time. But maybe the examples I've seen has been mis-labeled as C instead of C++...
                Dan Rathbun
                If you look near the top of the interface header files (ie: "Sketchup_i.h", etc.) you'll see that they are including support for OLE:
                %(#008080)[#include "ole2.h"]
                All the color properties (and getter methods,) return a %(#008080)[OLE_Color] type.
                There is also an interface: %(#008080)[ISkpRGBAArray]
                ... see the SDK documentation.
                Now for more low level, see:
                " %(#BF4000)[SkpWriter/Headers/source/common/utils/color.h]"
                Look at " %(#BF4000)[SkpWriter/Headers/source/sketchup/skpwriter/sapi/itexture.h]" for an example of accessing color methods.
                  Dan Rathbun
                  @thomthom said:
                  That is C++ though. ...
                  You are overlooking a fact that is "right under your nose." Not all 3rd party applications that need to use the SDK to work with SKP files, are written in C++. It is safe to assume that, a good number of them will be written in C. If you look through the header files, you will see that Google defined "C style" interface wrappers.
                  look:
                  #ifdef __cplusplus
                  typedef class SkpView SkpView;
                  #else
                  typedef struct SkpView SkpView;
                  #endif /* __cplusplus */
                  The part of your code that is C, is inside the:
                  %(#008080)[#ifdef __cplusplus extern "C" { ... } #endif /* __cplusplus */]
                  ... but (I believe,) within that you can call functions that are outside it, in the C++ part.
                    Dan Rathbun
                    Another thing.. do not assume your C code is wrapped or protected.
                    You could create a conflict with another %(#008080)[struct Color], defined by someone else's extension, or perhaps even defined by the Windows API (or whatever.)
                    I'd advise you to prefix any identifiers not inside a function, with "tt_" (and perhaps then add a secondary prefix for whatever lib or plugin the C code is for.)
                    Did you notice how all ruby C functions are prefixed with "rb_" ??
                    Anyway.. say you write your lib module in C...
                    use something like:
                    %(#008080)[m_tt_Lib2 c_tt_Lib2_MatlImporter]
                    .. whatever.. come up with a unique prefix, to prevent clashes.
                      You could create a conflict with another struct Color, defined by someone else's extension, or perhaps even defined by the Windows API (or whatever.)
                      No, my functions are all static - so they are isolated to the source file they are defined in. I hadn't made the structs static yet though.
                        Regardless, C++ allow for definition of variables anywhere in the scope, C doesn't. Can't get away from that. That's why I was wondering how variable initializion in C works. Examples such as: http://en.wikipedia.org/wiki/Static_variable
                        Guess I just need to try it out. See if it works.
                          Did you notice all the rb_ functions are not static? While there's a bunch of other functions not prefixed with rb_ which are all static is not part of the API.
                          Since there is no namespace or classes in C, static and extern is what controls what is exposed to the whole environment.
                            After snooping around the Ruby source and looking how it's done there, it looks like this is the way to go:
                            <span class="syntaxdefault">struct Color<br /></span><span class="syntaxkeyword">{<br /></span><span class="syntaxdefault">  unsigned char red</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> green</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> blue</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> alpha</span><span class="syntaxkeyword">;<br />};<br /><br /></span><span class="syntaxdefault">static VALUE<br />color_to_sketchup</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> Color color </span><span class="syntaxkeyword">)<br />{<br /></span><span class="syntaxdefault">  VALUE mSketchup</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> cColor</span><span class="syntaxkeyword">;<br /></span><span class="syntaxdefault">  VALUE skp_color</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> args</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">4</span><span class="syntaxkeyword">];<br /></span><span class="syntaxdefault">  <br />  mSketchup </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> rb_const_get</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> rb_cObject</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> rb_intern</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Sketchup"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  cColor </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> rb_const_get_at</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> mSketchup</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> rb_intern</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Color"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  <br />  args</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> rb_float_new</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> color</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">red </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  args</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> rb_float_new</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> color</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">green </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  args</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> rb_float_new</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> color</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">blue </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  args</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> rb_float_new</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> color</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">alpha </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  <br />  skp_color </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> rb_class_new_instance</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> 4</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> args</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> cColor </span><span class="syntaxkeyword">);<br /></span><span class="syntaxdefault">  <br />  return skp_color</span><span class="syntaxkeyword">;<br />}</span><span class="syntaxdefault"> </span>
