    Error checking routine issue?
    10 Posts 3 Posters 601 Views 3 Watching
    • T
      tomot
      The following statement works!
      if (@width < 2)
      UI.messagebox( "A Width of less than 2 is not allowed ")
      return nil
      Question: How do I combine less than and more than into one statement using Ruby?
      The Ruby API is not very clear on this. Neither of the 2 statements below work!
      if (@width < 2 > 12)
      UI.messagebox( "A Width of less than 2 or greater than 12 is not allowed ")
      return nil
      if ( 2 < @width > 12)
      return nil
      Tia!
      my plugins
      tomot
      • thomthomT
        Use the OR operator: ||
        <span class="syntaxdefault">if </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">width </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> 2 </span><span class="syntaxkeyword">||</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">width </span><span class="syntaxkeyword">></span><span class="syntaxdefault"> 12<br />  UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxstring">"A Width of less than 2 or greater than 12 is not allowed "</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  return nil<br />end</span>
        http://www.techotopia.com/index.php/Ruby_Operators#Ruby_Comparison_Operators
        • T
          tomot
          Thanks thomthom, I also just noticed I should have posted this in Developers' Forum ....my bad!
          my plugins
          tomot
          • thomthomT
            Moved it. Didn't notice it was in the Plugins section.
            • Dan RathbunD
              Dan Rathbun
              Nor would it be !
              The Google SketchUp Ruby API, consists of only 3 modules (and a lot of classes inside them.) Also a few additions to a couple of standard Ruby classes.
              This API, only extends standard Ruby, so we can work with Sketchup and it's models.
              You need to use the standard Ruby reference to understand what methods are available to the standard Ruby modules and classes.
              You need to read a good book on standard Ruby programming, to understand how to program in Ruby, before you can effectively know how to employ the SketchUp Ruby API's extensions. (This book is also distributed as a CHM, in the full Ruby install. See the "C:\Ruby186\doc" directory.)
              I'm not here much anymore.
              • Dan RathbunD
                Dan Rathbun
                You can also use the between? method:
                unless @width.between?(2,12)
                  return nil
                .. or you could use a literal Range object, and it's include? method:
                unless (2..12).include?(@width)
                  return nil
                You can also use a Range object's === method:
                unless (2..12) === @width
                  return nil
                • Dan RathbunD
                  Dan Rathbun
                  And you can also create referenced Range objects:
                  @valid_width = 2..12
                  @valid_width.class
                  Range
                  so..
                  return nil unless @valid_width === @width
                  • T
                    tomot
                    Thanks Dan! for raking me over the coals.... I needed that ...ouch! 😄
                    my plugins
                    tomot
                    • Dan RathbunD
                      Dan Rathbun
                      I just want you to understand where the information you need is at. (And that it is readily available.) Will save you a lot of grief.
                      Not a day goes by, without me opening both of these CHM references (they are both open right now, in fact, but minimized to the taskbar.)
                      • T
                        tomot
                        I understand fully! and that's why your 1 of 3 of my favorite "SU Ruby API goto guys"
                        I also have to include TIG! & thomthom!
                        my plugins
                        tomot
