    [REQ] Panel maker
    6 Posts 3 Posters 765 Views 3 Watching
      Mra
      I was wondering if it were possible or if anyone knew how to make this script?
      I have made this script in Maya but am not familiar enough with Ruby code to be able to do something this simple.
      Basically, I was wondering if there was a script that you could select a face, enter in a dimension and the script should offset the face and extrude it a little (like in the below screenshot on the two panels on the right). I know this can be done with existing tools, but when you have thousands of panels to make a script would be really cool!
      http://i.imgur.com/QrXZV.jpg
      Thanks.
      • jolranJ Offline
        jolran
        Hi!
        I will have some paneling features in "Hatchfaces"-plugin, soonish. Been busy with other stuff.
        Back to subject.. Does sounds like you only want to pushpull each face and scale it down a little to get an beveled edge? Not really paneling, then?
        Anyway, did some experimenting with pushpulls. And there could be issues of getting hold of the original face when pushpulled?(if I remembered correctly). To fix that I assigned a temp material to the face (so I could get a hold of it later on).
        That material can be discarded later on.
        Just some observations for anyone involved doing this plugins.
          Mra
          @jolran said:
          Hi!
          Hi jolran, sounds good!
          @jolran said:
          Hi!
          Yes, that is correct. It is almost a cheat, not really made up of individual panels, but the method gives off that illusion. I just honestly have no idea about Ruby but it seems this would be a simple process. πŸ˜„
          Thanks for the reply
          • jolranJ Offline
            jolran
            Hi!
            I understand your request. However to select each face and run a specialized plugin (in your case 1000 times) will be quite slow as well πŸ˜„
            Hatchfaces will run on only 1 face, but you will be able to do some tiling.
            Doing a plugin for your request would only need a pushpull(in face-normal direction) and some scaling with a simple dialog. That way multiple faces could be altered in 1 go.
            Not to difficult to do, I think?
            I'm swamped with things to do so I can't help you right now. But maybe later if nobody else is interested.
            • sdmitchS Offline
              sdmitch
              mra, give my Bevel Maker plugin a try. I think it might do what you want.
              http://sdmitch.blogspot.com/
              • jolranJ Offline
                jolran
                Hey! There you go πŸ‘
                Did not notice that plugin cause you have it on your blogg, Sdmitch. Sorry 😳
                Indeed seams to be able to meet the requirements in this request.
