    Adobe CS3 "AMT Subsystem Failure"
    4 Posts 2 Posters 495 Views 2 Watching
    • HieruH
      Hieru
      I've run into a bit of a headache with my installation of CS3 Design Premium.
      After trialing LumenRT I decided to uninstall it as SU has crashed on close since installation. Unfortunately this screwed up 50% of the programmes on my PC. Neither reverting to a working configuration or restore point undid the damage.
      For most programmes it was easy enough to repair or reinstall them. My CS3 suite is a different matter and none of the programmes will run because of the dreaded "AMT Subsystem Failure - The licensing subsystem has failed catastrophically". I've followed all of the solutions suggested by Adobe and others online, but nothing works. I can't even uninstall the suite in order to try reinstalling (Adobe's CS5 clean uninstall tool doesn't work).
      I've downloaded a trial of CS5.5 Design Premium as a temporary solution - which works just fine. Speaking with Adobe the only other remaining option - short of upgrading to CS5.5 - would be to reinstall my operating system.
      Has anyone else run into this problem and know of any solutions that might work?
      www.davidhier.co.uk
      • PixeroP
        Pixero
        Not sure this will help you but here are some links I Googled:
        http://photoshopnews.com/2007/04/16/adobe-technote-manually-remove-photoshop-cs3-public-beta-windows-xp/
        http://www.adobe.com/support/contact/cscleanertool.html
        http://www.raymond.cc/forum/software/8321-cs3-wont-uninstall-or-install-3.html
        • HieruH
          Hieru
          Thanks Pixero πŸ‘
          I've already tried the Creative Suite Cleaner, but the other two look promising.
          www.davidhier.co.uk
          • HieruH
            Hieru
            I've only tried one of the above solutions (with no success) but whilst looking at my options I thought that I could subscribe to CS5.5 whilst waiting for CS6. However I stumbled upon a slight problem that more people should be aware of.
            In the past Adobe offered good discounts when upgrading from the previous 3 versions. When CS6 is released these discounts will only apply to people who have CS5 😲
            www.davidhier.co.uk
