    Showing edges in color according to the main axes
    3 Posts 2 Posters 313 Views 2 Watching
    • G Offline
      glro
      Insert a component far from the origin 0 0 0, and give it the right orientation, is difficult because the global axis are not visible in the window
      you have to memorize where they are, or zoom out to see it, and then zoom in again to insert the component precisely
      Sketchup gives the possibility to color the objects edges according to their direction, which is great because this way, you always know where the main axes are, even if you are far from the origin
      Would it be possible to write a plugin that would toggle the edges color to the main axes, just by pressing a key on the keyboard?
      edges color acccording to main axes
        Jim's custom toolbar plugin has such a button.
        The one right to it will toggle endpoints - also a good thing when trouble shooting or connecting mesh.
        • G Offline
          glro
          [attachment=0:381h7ksq]<!-- ia0 -->CustomToolbar.png<!-- ia0 -->[/attachment:381h7ksq]
          thank you
          yes, i realized it later, and that i could do it myself...
          As an alternative to buttons, i like to use keyboard shortcuts; so i slightly modified Jim's plugin to assign a key to it
          Here is the code, without any garantee; it works with me, but i only copied and pasted, cannot explain what i did in detail ...
          require 'sketchup.rb'
          # Add a menu item to launch our plugin.
          UI.menu("PlugIns").add_item("colored_edges") { colored_edges }
          def colored_edges
          mod = Sketchup.active_model # Open model
          ent = mod.entities # All entities in model
          sel = mod.selection # Current selection
          ro = Sketchup.active_model.rendering_options
            ecm = ro["EdgeColorMode"]
            if ecm != 2
              ecm = 2
              Sketchup.set_status_text "Egde Color Mode; by Axis"
            else
              ecm = 1
              Sketchup.set_status_text "Egde Color Mode; Default"
            ro["EdgeColorMode"] = ecm
          def axisedge_validation_proc
            if Sketchup.active_model.rendering_options["EdgeColorMode"] == 2
              return MF_CHECKED
            else
              return MF_UNCHECKED
