    [code] Scraping API Docs
    1 Posts 1 Posters 1.1k Views 1 Watching
    • J
      Jim
      Example code for scraping the api docs pages. Might be useful for indexing or analysis...
      Use at your own risk - if you run it "too much," the Google machine will temporarily block you. Who knows what happens if you "abuse" it. I didn't look it up, but one should assume scraping is in violation of Google's Terms of Service.
      Just run it once and direct output to a file:
      $ scrape.rb > output.txt
      # Scrapes API docs for class names, method names, and method versions.
      require 'open-uri'
      require 'nokogiri'
      # ctrl-c on WinXP
      trap("INT") {
          $stderr.puts "abort."
          @abort = true
      base = "https://developers.google.com/"
      class_index_url = base + "sketchup/docs/classes"
      page = Nokogiri;;HTML(open(class_index_url))
      classes = {}
      page.css(".columns a").each do |link|
          classes[link.text] = link['href']
          break if @abort
      exit if @abort
      classes.each do |name, url|
          puts name
          loc = base + "sketchup/docs/ourdoc/" + name.downcase
          page = Nokogiri;;HTML(open(loc))
          page.css(".apireference").each do |elem|
              method_name    = elem.css(".itemname").text
              method_version = elem.css(".version").text
              puts "#{method_name},#{method_version}"
          puts
          break if @abort
      scrape.rb
