    Model and render this: Glass brick/block
    43 Posts 16 Posters 17.6k Views 16 Watching
    • soloS Offline
      solo
      The first one rendered for 12 minutes plus some change at 1200x600 default BSD settings
      The second was 33 minutes with a different preset (one of my optimised for thick glass interiors)
      http://www.solos-art.com
      • StinkieS Offline
        Stinkie
        I'm rendering this interior with TR1 as we speak. At 6000 pixels wide and supersampling set at 'High'. πŸ’š
        Wonder how long that one'll take. 😲 Ah, if only unbiased rendering were fast -we'd never have to worry about thresholds and the like again. πŸ˜‰
        • soloS Offline
          solo
          Yikes dude! That's an overkill, I'd suggest rendering at size needed and at normal super sampling, that will give a great result, or even high super sampling if you want perfection, but 6000 is crazy.
          Unbiased is fast, if you have enough cores or a render farm. πŸ’š
          • StinkieS Offline
            Stinkie
            @solo said:
            Yikes dude! That's an overkill, I'd suggest rendering at size needed (...)
            That is the size needed. It's a test to see how fast TR1 can deliver me images for printing. And er, you're speaking to someone who's rendered as wide as 20000. πŸ‘Ώ
            • soloS Offline
              solo
              Have you got one of those pesky 24 core 100 plus GB ram rigs? as 20000 wide it beyond anything i could imagine, planning to put a render on the side of a building?
              • StinkieS Offline
                Stinkie
                Nope, same old Mac Pro. A test I did a few years back.
                • HieruH Offline
                  Hieru
                  The other week I tried a 6000px by 3000px TR1 (high supersampling) render for a 360x180 panorama test. I gave up after 12 hours and realised that I needed to get my head around biased render settings.
                  Luckily your interior with thick glass preset worked really well Solo. And back on topic - really nice scene. Would be perfect if you randomly rotated and reversed some of the blocks for variation.
                  I can't wait to get back on track with my scene, but this week has been hell 😒 .
                  www.davidhier.co.uk
                  • N Offline
                    notareal
                    Supersamling high is good if you are going to render something to HD sizes or smaller. Not much use with high resolution renders used in posters or if you going to down scale them later. Perhaps some high precession printing can benefit from it.
                    • HieruH Offline
                      Hieru
                      I still haven't had chance to do much work on this, but here's a quick teaser of one of the elements I want to use in conjunction with the glass blocks.
                      www.davidhier.co.uk
                        sepo
                        Very nice feel to the render...but what happened to caustics? Shouldn't be some on the floor, right?
                        • HieruH Offline
                          Hieru
                          I'm not sure what happened - I was expecting something like this. It'll be an issue with the lighting or the ground material (which has very little reflectivity). Hopefully I can sort it out for my final scene.
                          www.davidhier.co.uk
                          • HieruH Offline
                            Hieru
                            I had a bit of time this afternoon to do some work on this. I started out modelling a basic glass block, but sort of overdid the modelling. I could have just kept things simple (push/pull, follow me and some rounded edges), but working from a 2D CAD drawing I was determined to be as accurate as possible and basic modelling was proving a pain when it came to the concave centre profile.
                            In the end I decided that Artisan was the best tool for the job:
                            And here's a test render - checking the caustics and deformation:
                            I then set up a rough room/scene to test some lighting ideas:
                            So with all the above shaping up, I've now got a good idea of what I want to do for my final scene.
                            www.davidhier.co.uk
                            • cheddaC Offline
                              chedda
                              Looking good Heiru, especially the modelling although i suspect it's overkill, how does your machine behave with all those poly's, especially when you have multiple instances ?
                              Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                              • HieruH Offline
                                Hieru
                                As expected SU grinds and groans under the strain. Even the Thea exporter has trouble when using my preferred settings.
                                For this exercise I'll stick with the high poly model, but I've already modelled something simpler for real-world situations.
                                www.davidhier.co.uk
                                • HieruH Offline
                                  Hieru
                                  I'm not quite happy with this, but I think this will be my last attempt at the challenge.
                                  www.davidhier.co.uk
                                  • dereiD Offline
                                    derei
                                    What render engine did you used? I like the caustics very much!
                                    DESIGNER AND ARTIST DEREI.UK
                                    • HieruH Offline
                                      Hieru
                                      The whole idea was based around the caustics, so I'm glad you like the effect.
                                      The scene was rendered using Thea.
                                      www.davidhier.co.uk
                                        Roger
                                        The see through bathtub works well with the candles. Add a little wine and some flamenco playing over hidden speakers.
                                        http://www.azcreative.com
                                        • dereiD Offline
                                          derei
                                          And a chick !! (be sure is not the kind with feathers πŸ’š ) πŸ‘
                                          • jason_marantoJ Offline
                                            jason_maranto
                                            Excellent model and rendering! πŸ‘ πŸ‘
                                            Best,
                                            Jason.
                                            • 2 / 3
