    [Code] Scarpino's SphereTool Sample ver 2.1.0
    15 Posts 2 Posters 4.3k Views 2 Watching
    • Dan RathbunD
      Dan Rathbun
      Automatic SketchUp
      Creating 3-D Models in Ruby
      by Matthew Scarpino
      SphereTool Sample Plugin (correction - Topic is WIP)
      page 260 ..
      This sample has been corrected to:
      • Wrap the tool class inside a plugin module, within an author toplevel module.
      • Use variables inside the namespace instead of global variables.
      • Separate plugin code, from tool code into two files, to show file spanning, and how to save indents.
      • Use active_entities instead of entities, so a user can add a sphere to a group or component.
      • Add a rescue block and Undo operation around the geometry drawing code, for safety.
      SphereMaker
      ver 2.0.0 : 02-09-2012
      • initial posting
        ver 2.1.0 : 02-10-2012
      • added some model tracking in to account for switching back and forth between models on Mac.
        ver 2.2.0 : 02-11-2012
      • ! BACKPORT: Tracking models proves to be problematic. Reverted to singleton use of the SphereTool class.
      • ~ Method tool() backported to the 2.0.0 use() method's functionality. Creates the tool instance, only if needed, and/or returns a reference to it.
        VERSION 2.2.1 : 02-14-2012
      • Removed definition of WIN and MAC constants. (Not used, nor relevant to this example.)
      This sample plugin file (below, along with the toolbar icon files,) should go in it's own subdir, of the author's subdir, of the "Plugins" dir.
      "Plugins/Scarpino/SphereMaker/spheremaker.rb"
      #   file ; 'spheremaker.rb'
      #   by   ;  Dan Rathbun
      #{  Description;
      #   Example of namespace wrapping the 'spheretool.rb' file,
      #   from "Automatic SketchUp" by Matthew Scarpino, pg 260.
      #{  Versions;
      #   2.0.0  ;  02-09-2012
      #   + initial posting (not tested)
      #   2.1.0  ;  02-10-2012
      #   + Added tool() method for model tracking to account
      #       for switching back and forth between models on
      #       Mac.  Returns tool instance per model.
      #   ~ Changed use() method to call tool() and select it
      #       as the active tool.
      #   2.2.0  ;  02-11-2012
      #   ! BACKPORT; Tracking models proves to be problematic.
      #       Reverted to singleton use of the SphereTool class.
      #   ~ Method tool() backported to the 2.0.0 use() method's
      #       functionality. Creates the tool instance, only if
      #       needed, and/or returns a reference to it.
      #   2.2.1  ;  02-14-2012
      #   ~ Removed definition of WIN and MAC constants.
      #     (Not used, nor relevant to this example.)
        #{# DEPENDENCIES
          require('sketchup.rb')
      module Scarpino  # <-- Author's namespace
        module SphereMaker # <-- plugin namespace
          ### CONSTANTS
          VERSION = '2.2.1'
          ### MODULE VARIABLES
          @@cmd     = nil unless defined?(@@cmd)
          @@tool    = nil unless defined?(@@toolset)
          @@toolbar = nil unless defined?(@@toolbar)
          ### Load the tool code for SphereTool
          require('Scarpino/SphereMaker/spheretool.rb')
          ### class SphereTool is now local to this module
          ### MODULE METHODS
          #  cmd()
          #    Returns a reference to this plugin's UI;;Command object.
          def self.cmd
            @@cmd
          #  tool()
          #    Returns the tool instance. Creates one if needed.
          def self.tool
            if not @@tool
              @@tool = SphereTool.new
            else
              @@tool
          end # def
          #  toolbar()
          #    Returns a reference to this plugin's UI;;Toolbar object.
          def self.toolbar
            @@toolbar
          #  use()
          #    Gets the tool instance, and makes it
          #      the active tool for the model argument.
          #    [Defaults to use the active model.]
          def self.use( mod = Sketchup.active_model )
            unless mod.is_a?(Sketchup;;Model)
              raise(TypeError,"Sketchup;;Model argument expected.",caller)
            mod.select_tool( self.tool )
          end # def
          ### RUN ONCE
          unless file_loaded?(File.basename(__FILE__))
            # Create the Command object
            @@cmd = UI;;Command.new("Sphere") { self.use }
            # Configure the Command's appearance
            @@cmd.small_icon = "sphere_small.gif"
            @@cmd.large_icon = "sphere_large.gif"
            @@cmd.tooltip = "Create a sphere"
            # Create and configure the Toolbar
            @@toolbar = UI;;Toolbar.new "Sphere"
            @@toolbar.add_item @@cmd
            @@toolbar.show
            file_loaded(File.basename(__FILE__))
          ### RUN ONCE
        end # module SphereMaker
      end # module Scarpino
      The global methods file_loaded and file_loaded? come from 'sketchup.rb', which is in the "Tools" dir.
      SphereTool
      • initial posting (not tested)
      • $ents changed to @@ents, and made to use the active_entities, instead of model.entities
      • $c_point changed to [ruby:s6njewt4]@@c_point[/ruby:s6njewt4]
      • Added undo operation and rescue block around model geometry creation.
      • @@ents changed to [ruby:s6njewt4]@ents[/ruby:s6njewt4]
      • [ruby:s6njewt4]@@c_point[/ruby:s6njewt4] changed to [ruby:s6njewt4]@c_point[/ruby:s6njewt4]
      • Added tracking of current editing context. (User can change editing context "on-the-fly" anytime via the right-click popup menus, "Edit Group" and "Close Group", etc.)
      • Added query method [ruby:s6njewt4]edit_context_changed?()[/ruby:s6njewt4]
        UNDER REVISION
      This file is: "Plugins/Scarpino/SphereMaker/spheretool.rb"
      # file ; 'spheretool.rb'
      # from ; "Automatic SketchUp"
      # by   ; by Matthew Scarpino
      # page ; 260
      # ver  ; 2.1.0
      # edit ; Dan Rathbun
      class Scarpino;;SphereMaker;;SphereTool
        ### CONSTANTS
        VERSION = '2.1.0'
        ### INIT INSTANCE VARIABLES
        # Set up the private method initialize(), which
        # is called by the class constructor method new().
        def initialize(*args)
          @mod  = Sketchup.active_model
          @ents = nil
          @c_point = nil
          @pt1 = Sketchup;;InputPoint.new
          @pt2 = Sketchup;;InputPoint.new
        private(;initialize)
        ### CONTROL CALLBACK METHODS
          #  activate()
          def activate()
            @ents = @mod.active_entities
              # The points clicked by the user
            @c_point = nil
            @pt1.clear
            @pt2.clear
              # The initial state (user hasn't clicked yet)
            @first_click = false
          #  deactivate( view )
          def deactivate( view )
            if @first_click
              @ents.erase_entities( @c_point ) if @c_point
              @c_point = nil
            @ents = nil # we want to refresh this each time
          #  edit_context_changed?()
          def edit_context_changed?()
            ents_now = @mod.active_entities
            unless bool = ents_now.equal?(@ents)
              if @first_click && @c_point
                # move c_point to new context
                @ents = ents_now
                @c_point = @ents.add_cpoint @pt1.position
            return bool
          #  suspend( view )
          def suspend( view )
          #  reset()
          #    Return to original state
          def reset()
            @pt1.clear
            @pt2.clear
          #  resume( view )
          def resume( view )
            # check if editing context has changed
            view.invalidate
        ### KEYPRESS CALLBACK METHODS
          #  onCancel( flags, view )
          #    Respond when user presses Escape
          def onCancel( flags, view )
            if @first_click
              @c_point = nil
            reset
          #  onMouseMove( flags, x, y, view )
          #    If the user clicked, draw a line.
          def onMouseMove( flags, x, y, view )
            if @first_click
              @pt2.pick view, x, y, @pt1
              view.invalidate
          #  onLButtonDown( flags, x, y, view )
          #    Check the state, then draw a sphere or a point.
          def onLButtonDown( flags, x, y, view )
            if @first_click
              if (@pt1.position.distance @pt2.position) > 0
                # Remove the construction point
                @ents.erase_entities @c_point
                @c_point = nil
                draw_sphere
            else # this is the first click
              # get the active editing context
              @pt1.pick view, x, y
              @first_click = true
        ### DRAWING METHODS
          #  draw( view )
          def draw( view )
            if @first_click && @pt2.valid?
              view.set_color_from_line @pt1.position, @pt2.position
              view.line_width = 3
              view.draw_line @pt1.position, @pt2.position
          #  draw_sphere()
          #    Draw the sphere
          def draw_sphere
            # Draw the circles
            begin
              @mod.start_operation('Draw Sphere')
                rad = @pt1.position.distance @pt2.position
                circle = @ents.add_circle @pt1.position, [1, 0, 0], rad
                path = @ents.add_circle @pt1.position, [0, 1, 0], rad + 1
                circle_face = @ents.add_face circle
                # Extrude the sphere and erase the extrusion path
                circle_face.followme path
                @ents.erase_entities path
              @mod.commit_operation
            rescue
              @mod.abort_operation
            ensure
              reset
        ### RUN ONCE
        thisfile = File.basename(__FILE__)
        file_loaded( thisfile ) unless file_loaded?( thisfile )
      end # class Scarpino;;SphereMaker;;SphereTool
      Then in the "Plugins" dir, the author puts a [ruby:s6njewt4]SketchupExtension[/ruby:s6njewt4] registration script.
      "Plugins/Scarpino_spheremaker_ext.rb"
      (To Do - insert "ext" ruby script here )
      I suggest prepending your extension loader scripts with your Author **namespace+""**, and appending the filename with "_ext" (so we all know that it registers a Sketchup extension.)
      See the following Google Sketchup API blog posts:
      • Turn Your Plugin Into An Extension (July 21, 2011)
      • Being a Good SketchUp Ruby Citizen Wednesday, (August 3, 2011)
      • RBZs in SketchUp 8M2: Distribute Your Plugin as One File! (December 1, 2011)
        See also my sample at SCF:
      • SketchupExtension and rbs rubies (August 2, 2011)
      I'm not here much anymore.
      • Dan RathbunD
        Dan Rathbun
        Just a not that this sample tool should work OK for PC.. but not for MAC with multiple models.
        I'll have to add some model tracking in to account for switching back and forth between models.
        • D
          driven
          Hi Dan,
          If people are working through Matt's Tutorials the path could remain /Library/Application Support/Google SketchUp */SketchUp/plugins/asu_example_code/Ch11/sphere_tool.rb...
          I did a lot of testing for Mat's book and I didn't have a problem with this one one the mac, where do you think it will fail?
          The one we just couldn't get working on a mac, in the time frame for publication, was 'Skel Animation', please, please have a look at it
          Just curious...
          • Dan RathbunD
            Dan Rathbun
            Updated examples to VERSION 2.1.0
            Seems to work well on PC.
            Mac testing welcome (as it wants to be a cross-platform coding example.)
            • Dan RathbunD
              Dan Rathbun
              My point is that as the example is.. it violates good practice. It is not wrapped in an Author namespace. We cannot all be defining classes in the global ObjectSpace. There will be clashes. The identifier "SphereTool" is just too common.
              Likewise.. it makes sense to have the textnames of your filespaces match your Ruby namespaces. It makes it much easier, when the time comes to type a require statement.
              It will fail because the entities object is shared. In the example it used $ents, and I changed it to a class var @@ents.
              If you have 2 models, open, and are using the the sphere tool on both models, and switch back and forth, between models... the tool should get confused. Both as to what context to add the geometry into, and what one to erase the center $c_point from.
              I've already changed $ents / @@ents and $c_point / @@c_point to instance vars in the tool code.
              I have also already modified the plugin methods, to track models, use the correct one, and keep an separate instance of the tool for each model.
              Well, not having a Mac.. it will be difficult, unless I can spot some obvious booboo (or am aware of some kind bug on Mac.)
              I did not really choose this one... it was posted publically by Keld, so I got "hooked"...
              • D
                driven
                I'll try and find all my notes re. skell, interestingly, from what you just outlined, it may suffer from 'entities confusion', sometimes it ran and other times it just melted SU...
                With Mat's help, I attempted to have this one work along the user drawn axis, so you could e.g. create a string of pearls.
                Could you add or suggest how that could be done?
                Then it's quite different from all the others.
                john
                like so...
                • D
                  driven
                  Ok, all works on my mac,
                  I had to add the full path to the
                  require("/Library/Application Support/Google SketchUp 8/SketchUp/plugins/Scarpino/SphereMaker/spheretool.rb")
                  and I used a couple of icons I had from the last play, and I just used same full folder path for them as well.one I made earlieractually two
                  I'll make some nicer ones if you want, this was my first attempt at making icons in SU... john
                  • Dan RathbunD
                    Dan Rathbun
                    See a new post (... I must have been reading your mind.)
                    I made a Library edition:
                    [ Code ] Scarpino's SphereUtil Sample
                    • Dan RathbunD
                      Dan Rathbun
                      @driven said:
                      I had to add the full path ... john
                      Oh to get SU to find the icons ??
                      I can prepend the icon paths with: File.basename(__FILE__)
                      ... the UI::Command class is cranky sometimes, with the icon locations.
                      The icons look fine.. it's an example anyway.
                      I could tie it all up in an rbz for easy download. (Need to do the extension registration script first.)
                      • D
                        driven
                        @dan rathbun said:
                        VERSION 2.1.0
                        I don't follow what's meant to happen, can't see anything new in my context menu.
                        When you switch between models, you switch tool and undo stacks automatically.
                        am I being dim? john
                        no, before trying with icons, the path was failing.
                        I always use full or defined paths with require, it seems flakey. i.e. require path + "find"
                        OT: have you use find.rb with SU, it really shows up problems with 'Path' on mac's.
                        • Dan RathbunD
                          Dan Rathbun
                          Just a note, that when I referred to context menu, I was referring to entering and exiting group/component edit modes, via the context popup items "Edit Group" and "Close group".
                          You have to point to the group and right-click the mouse (or you don't see these items on the popup.)
                          Previously, the example tool, ignored any change in context, in fact, it was hard-coded to ALWAYS use the model's entities. So as Matt wrote it, you could not draw a sphere inside a group or component.
                          So in 2.0.0, I changed it to use active_entities, but once the construction point (for the center,) was drawn, the tool would put the sphere in the edit context of the c_point, even if the user had changed the edit context.
                          Version 2.1.0, checks to see if the edit context has changed when the second click is made, and acts within the new context, instead.
                          • Dan RathbunD
                            Dan Rathbun
                            Well it on PC we can use a singleton instance of a tool, there's only one stack, and model.
                            But on Mac, this example now makes a new tool for each model's toolstack, but only ONCE.
                            His example was actually creating a new instance EACH time the toolbar button was clicked. That makes ruby garbage collection do more work.
                            And he was having ALL instances (models,) share 2 global variables. $ents and $c_point
                            • D
                              driven
                              @dan,
                              I missed the fact you started the 2nd thread for this. I had 'another look at line tool, but what I meant is more like the Cyl.class at the bottom.
                              i.e. After the user draws a line, a base circle 'path' is created, then at the line's 'mid-position' a 'filled circle' at 90º to path, with rad 1/2 line length is created, then the follow-me, clean-up, etc...
                              You end up with the new axis aligned to the original drawn line and could select the end point to continue a 'string of pearls'... If you the intersect those, the geometry could be line-up, without having to rotate groups manually. However, clytool dosen't work here...
                              I've been distracted by almost having a WebDialog do the same things as my macMessage video shows. [but it's an 'almost' standard webdialog].
                              john
                              • Dan RathbunD
                                Dan Rathbun
                                @driven said:
                                @dan, I missed the fact you started the 2nd thread for this. I had 'another look at line tool, but what I meant is more like the Cyl.class at the bottom.
                                Oh OK. Well.. you wish to do it the easy way, huh ? 😛
                                That's subclassing a current class... a topic for a new thread.
                                • Dan RathbunD
                                  Dan Rathbun
                                  A note about toolbar icons.
                                  GIFs are not the best. (They are good for print ads, cartoons, etc.) But the edges look ragged.
                                  You should save as PNG, as the edges are anti-aliased. (smoothed via blending.)
