[Code] Scarpino's SphereTool Sample ver 2.1.0
Automatic SketchUp
Creating 3-D Models in Ruby
by Matthew ScarpinoSphereTool Sample Plugin (correction - Topic is WIP)
page 260 ..This sample has been corrected to:
- Wrap the tool class inside a plugin module, within an author toplevel module.
- Use variables inside the namespace instead of global variables.
- Separate plugin code, from tool code into two files, to show file spanning, and how to save indents.
- Use
active_entitiesinstead ofentities, so a user can add a sphere to a group or component. - Add a
rescueblock and Undooperationaround the geometry drawing code, for safety.
SphereMaker
ver 2.0.0 : 02-09-2012
initial posting
ver 2.1.0 : 02-10-2012 -
added some model tracking in to account for switching back and forth between models on Mac.
ver 2.2.0 : 02-11-2012 -
! BACKPORT: Tracking models proves to be problematic. Reverted to singleton use of the
SphereToolclass. -
~ Method
tool()backported to the 2.0.0use()method's functionality. Creates the tool instance, only if needed, and/or returns a reference to it.
VERSION 2.2.1 : 02-14-2012 -
Removed definition of
WINandMACconstants. (Not used, nor relevant to this example.)
This sample plugin file (below, along with the toolbar icon files,) should go in it's own subdir, of the author's subdir, of the "Plugins" dir.
"Plugins/Scarpino/SphereMaker/spheremaker.rb"# --------------------------------------------------------- # file ; 'spheremaker.rb' # by ; Dan Rathbun #{ --------------------------------------------------------- #{ Description; # # Example of namespace wrapping the 'spheretool.rb' file, # from "Automatic SketchUp" by Matthew Scarpino, pg 260. #} # --------------------------------------------------------- #{ Versions; # # 2.0.0 ; 02-09-2012 # + initial posting (not tested) # # 2.1.0 ; 02-10-2012 # + Added tool() method for model tracking to account # for switching back and forth between models on # Mac. Returns tool instance per model. # ~ Changed use() method to call tool() and select it # as the active tool. # # 2.2.0 ; 02-11-2012 # ! BACKPORT; Tracking models proves to be problematic. # Reverted to singleton use of the SphereTool class. # ~ Method tool() backported to the 2.0.0 use() method's # functionality. Creates the tool instance, only if # needed, and/or returns a reference to it. # # 2.2.1 ; 02-14-2012 # ~ Removed definition of WIN and MAC constants. # (Not used, nor relevant to this example.) #} #} --------------------------------------------------------- #{# DEPENDENCIES # require('sketchup.rb') # #}# module Scarpino # <-- Author's namespace module SphereMaker # <-- plugin namespace ### CONSTANTS # VERSION = '2.2.1' ### MODULE VARIABLES # @@cmd = nil unless defined?(@@cmd) @@tool = nil unless defined?(@@toolset) @@toolbar = nil unless defined?(@@toolbar) ### Load the tool code for SphereTool # require('Scarpino/SphereMaker/spheretool.rb') # ### class SphereTool is now local to this module ### MODULE METHODS # cmd() # Returns a reference to this plugin's UI;;Command object. def self.cmd @@cmd end # tool() # Returns the tool instance. Creates one if needed. def self.tool if not @@tool @@tool = SphereTool.new else @@tool end end # def # toolbar() # Returns a reference to this plugin's UI;;Toolbar object. def self.toolbar @@toolbar end # use() # Gets the tool instance, and makes it # the active tool for the model argument. # [Defaults to use the active model.] # def self.use( mod = Sketchup.active_model ) # unless mod.is_a?(Sketchup;;Model) raise(TypeError,"Sketchup;;Model argument expected.",caller) end # mod.select_tool( self.tool ) # end # def ### RUN ONCE # unless file_loaded?(File.basename(__FILE__)) # Create the Command object @@cmd = UI;;Command.new("Sphere") { self.use } # Configure the Command's appearance @@cmd.small_icon = "sphere_small.gif" @@cmd.large_icon = "sphere_large.gif" @@cmd.tooltip = "Create a sphere" # Create and configure the Toolbar @@toolbar = UI;;Toolbar.new "Sphere" @@toolbar.add_item @@cmd @@toolbar.show file_loaded(File.basename(__FILE__)) end # ### RUN ONCE end # module SphereMaker end # module ScarpinoThe global methods
file_loadedandfile_loaded?come from 'sketchup.rb', which is in the "Tools" dir.
SphereTool
- initial posting (not tested)
$entschanged to@@ents, and made to use theactive_entities, instead ofmodel.entities$c_pointchanged to [ruby:s6njewt4]@@c_point[/ruby:s6njewt4]- Added undo
operationandrescueblock around model geometry creation.
@@entschanged to [ruby:s6njewt4]@ents[/ruby:s6njewt4]- [ruby:s6njewt4]@@c_point[/ruby:s6njewt4] changed to [ruby:s6njewt4]@c_point[/ruby:s6njewt4]
- Added tracking of current editing context. (User can change editing context "on-the-fly" anytime via the right-click popup menus, "Edit Group" and "Close Group", etc.)
- Added query method [ruby:s6njewt4]edit_context_changed?()[/ruby:s6njewt4]
UNDER REVISION
This file is: "Plugins/Scarpino/SphereMaker/spheretool.rb"
# --------------------------------------------------------- # file ; 'spheretool.rb' # from ; "Automatic SketchUp" # by ; by Matthew Scarpino # page ; 260 # --------------------------------------------------------- # ver ; 2.1.0 # edit ; Dan Rathbun # --------------------------------------------------------- require('sketchup.rb') class Scarpino;;SphereMaker;;SphereTool ### CONSTANTS # VERSION = '2.1.0' ### INIT INSTANCE VARIABLES # # Set up the private method initialize(), which # is called by the class constructor method new(). # def initialize(*args) @mod = Sketchup.active_model @ents = nil @c_point = nil @pt1 = Sketchup;;InputPoint.new @pt2 = Sketchup;;InputPoint.new end private(;initialize) ### CONTROL CALLBACK METHODS # # activate() # def activate() @ents = @mod.active_entities # The points clicked by the user @c_point = nil @pt1.clear @pt2.clear # The initial state (user hasn't clicked yet) @first_click = false end # deactivate( view ) # def deactivate( view ) if @first_click @ents.erase_entities( @c_point ) if @c_point @c_point = nil end @ents = nil # we want to refresh this each time end # edit_context_changed?() # def edit_context_changed?() ents_now = @mod.active_entities unless bool = ents_now.equal?(@ents) if @first_click && @c_point # move c_point to new context @ents.erase_entities( @c_point ) # @ents = ents_now @c_point = @ents.add_cpoint @pt1.position end end return bool end # suspend( view ) # def suspend( view ) # end # reset() # Return to original state # def reset() @pt1.clear @pt2.clear @first_click = false end # resume( view ) # def resume( view ) # check if editing context has changed edit_context_changed? # view.invalidate end # ### ### KEYPRESS CALLBACK METHODS # # onCancel( flags, view ) # Respond when user presses Escape # def onCancel( flags, view ) if @first_click @ents.erase_entities( @c_point ) if @c_point @c_point = nil end reset end # onMouseMove( flags, x, y, view ) # If the user clicked, draw a line. # def onMouseMove( flags, x, y, view ) if @first_click @pt2.pick view, x, y, @pt1 view.invalidate end end # onLButtonDown( flags, x, y, view ) # Check the state, then draw a sphere or a point. # def onLButtonDown( flags, x, y, view ) if @first_click # check if editing context has changed edit_context_changed? if (@pt1.position.distance @pt2.position) > 0 # Remove the construction point @ents.erase_entities @c_point @c_point = nil draw_sphere end else # this is the first click # get the active editing context @ents = @mod.active_entities @pt1.pick view, x, y @c_point = @ents.add_cpoint @pt1.position @first_click = true end end # ### ### DRAWING METHODS # # draw( view ) # def draw( view ) if @first_click && @pt2.valid? view.set_color_from_line @pt1.position, @pt2.position view.line_width = 3 view.draw_line @pt1.position, @pt2.position end end # draw_sphere() # Draw the sphere # def draw_sphere # Draw the circles begin @mod.start_operation('Draw Sphere') # rad = @pt1.position.distance @pt2.position circle = @ents.add_circle @pt1.position, [1, 0, 0], rad path = @ents.add_circle @pt1.position, [0, 1, 0], rad + 1 circle_face = @ents.add_face circle # Extrude the sphere and erase the extrusion path circle_face.followme path @ents.erase_entities path # @mod.commit_operation rescue @mod.abort_operation ensure reset end end # ### ### RUN ONCE # thisfile = File.basename(__FILE__) file_loaded( thisfile ) unless file_loaded?( thisfile ) end # class Scarpino;;SphereMaker;;SphereToolThen in the "Plugins" dir, the author puts a [ruby:s6njewt4]SketchupExtension[/ruby:s6njewt4] registration script.
"Plugins/Scarpino_spheremaker_ext.rb"
(To Do - insert "ext" ruby script here )
I suggest prepending your extension loader scripts with your Author **namespace+""**, and appending the filename with "_ext" (so we all know that it registers a Sketchup extension.)See the following Google Sketchup API blog posts:
Being a Good SketchUp Ruby Citizen Wednesday, (August 3, 2011)
RBZs in SketchUp 8M2: Distribute Your Plugin as One File! (December 1, 2011)
See also my sample at SCF:
Just a not that this sample tool should work OK for PC.. but not for MAC with multiple models.
I'll have to add some model tracking in to account for switching back and forth between models.
Hi Dan,
If people are working through Matt's Tutorials the path could remain
/Library/Application Support/Google SketchUp */SketchUp/plugins/asu_example_code/Ch11/sphere_tool.rb...I did a lot of testing for Mat's book and I didn't have a problem with this one one the mac, where do you think it will fail?
The one we just couldn't get working on a mac, in the time frame for publication, was 'Skel Animation', please, please have a look at it
Just curious...
Updated examples to VERSION 2.1.0
Seems to work well on PC.
Mac testing welcome (as it wants to be a cross-platform coding example.)
/Library/Application Support/Google SketchUp */SketchUp/plugins/asu_example_code/Ch11/sphere_tool.rb...My point is that as the example is.. it violates good practice. It is not wrapped in an Author namespace. We cannot all be defining classes in the global
ObjectSpace. There will be clashes. The identifier "SphereTool" is just too common.Likewise.. it makes sense to have the textnames of your filespaces match your Ruby namespaces. It makes it much easier, when the time comes to type a
It will fail because the entities object is shared. In the example it used
$ents, and I changed it to a class var@@ents.If you have 2 models, open, and are using the the sphere tool on both models, and switch back and forth, between models... the tool should get confused. Both as to what context to add the geometry into, and what one to erase the center
$c_pointfrom.I've already changed
$ents/@@entsand$c_point/@@c_pointto instance vars in the tool code.
I have also already modified the plugin methods, to track models, use the correct one, and keep an separate instance of the tool for each model.@driven said:
Well, not having a Mac.. it will be difficult, unless I can spot some obvious booboo (or am aware of some kind bug on Mac.)
I did not really choose this one... it was posted publically by Keld, so I got "hooked"...
I'll try and find all my notes re. skell, interestingly, from what you just outlined, it may suffer from 'entities confusion', sometimes it ran and other times it just melted SU...
With Mat's help, I attempted to have this one work along the user drawn axis, so you could e.g. create a string of pearls.
Could you add or suggest how that could be done?
Then it's quite different from all the others.
Ok, all works on my mac,
I had to add the full path to the
require("/Library/Application Support/Google SketchUp 8/SketchUp/plugins/Scarpino/SphereMaker/spheretool.rb")
and I used a couple of icons I had from the last play, and I just used same full folder path for them as well.
I'll make some nicer ones if you want, this was my first attempt at making icons in SU... john -
See a new post (... I must have been reading your mind.)
I made a Library edition:
[ Code ] Scarpino's SphereUtil Sample -
@driven said:
I had to add the full path ... john
Oh to get SU to find the icons ??
I can prepend the icon paths with:
File.basename(__FILE__)... the
UI::Commandclass is cranky sometimes, with the icon locations.The icons look fine.. it's an example anyway.
I could tie it all up in an rbz for easy download. (Need to do the extension registration script first.)
@dan rathbun said:
VERSION 2.1.0
added some model tracking in to account for switching back and forth between models on Mac.I don't follow what's meant to happen, can't see anything new in my context menu.
When you switch between models, you switch tool and undo stacks automatically.am I being dim? john
no, before trying with icons, the path was failing.
I always use full or defined paths with require, it seems flakey. i.e.require path + "find"
OT: have you use find.rb with SU, it really shows up problems with 'Path' on mac's. -
Just a note, that when I referred to context menu, I was referring to entering and exiting group/component edit modes, via the context popup items "Edit Group" and "Close group".
You have to point to the group and right-click the mouse (or you don't see these items on the popup.)
Previously, the example tool, ignored any change in context, in fact, it was hard-coded to ALWAYS use the model's entities. So as Matt wrote it, you could not draw a sphere inside a group or component.
So in 2.0.0, I changed it to use
active_entities, but once the construction point (for the center,) was drawn, the tool would put the sphere in the edit context of thec_point, even if the user had changed the edit context.Version 2.1.0, checks to see if the edit context has changed when the second click is made, and acts within the new context, instead.
Well it on PC we can use a singleton instance of a tool, there's only one stack, and model.
But on Mac, this example now makes a new tool for each model's toolstack, but only ONCE.
His example was actually creating a new instance EACH time the toolbar button was clicked. That makes ruby garbage collection do more work.
And he was having ALL instances (models,) share 2 global variables.$entsand$c_point -
@dan,
I missed the fact you started the 2nd thread for this. I had 'another look at line tool, but what I meant is more like the Cyl.class at the bottom.i.e. After the user draws a line, a base circle 'path' is created, then at the line's 'mid-position' a 'filled circle' at 90ΒΊ to path, with rad 1/2 line length is created, then the follow-me, clean-up, etc...
You end up with the new axis aligned to the original drawn line and could select the end point to continue a 'string of pearls'... If you the intersect those, the geometry could be line-up, without having to rotate groups manually. However, clytool dosen't work here...I've been distracted by almost having a WebDialog do the same things as my macMessage video shows. [but it's an 'almost' standard webdialog].
A note about toolbar icons.
GIFs are not the best. (They are good for print ads, cartoons, etc.) But the edges look ragged.
You should save as PNG, as the edges are anti-aliased. (smoothed via blending.)
