    Lumen RT Plugin not working
    extensions
    25 Posts 6 Posters 17.6k Views 6 Watching
      dburdick
      @syndicate said:
      FIXED!!! I realized that the console told me the settings.ini file was denied permission. I used a handy little tool called "Take Own" and took ownership of the LumenRT 2 folder and Voila!
      Glad you got it working - let us know what you think after your test runs.
      Regards,
      Dave
      • W Offline
        whiterabbit
        I have same issue. no export function suddenly, tried a reinstall too.
        below is the ruby info. Only material editor appears. No export from dropdown menu or from lumenrt buttons. If I have a selection I do get the window that asks if I want to export the whole model or just the selection, but either way...nothing happens.
        Setting Default Settings
        Error: #<NoMethodError: undefined method strip' for nil:NilClass> (eval):2295:in get_SavedSettings'
        (eval):2292:in each' (eval):2292:in get_SavedSettings'
        (eval):1926:in initialize' (eval):241:in new'
        (eval):241:in lumenRT_exportModel' (eval):552:in load'
        (eval):2296:in `call'
        (eval):2296
          dburdick
          Hi WhiteRabbit,
          Look like the Setting.ini may be corrupted. Go to ProgramFiles/LumenRT 4 Studio/LumenRT/Skp/Ruby and delete the Settings.ini file. Then, restart Sketchup and try firing up LRT again. It will create a new Settings.ini file.
            reno94
            HI. I can help you regarding your problem why nothing model scene during exporting 3d. Well, you need to GROUP or make COMPONENTS of all your materials (like Walls, Tables, Door, etc.) in sketchup before Exporting to 3d. as a result, all which GROUPED materials (like Walls, Tables, Door, etc.) are only be exported to 3D, which is ".dae" files. IF you DON'T GROUP OF MAKE COMPONENTS, there will be nothing to do with exporting.
            sorry for my bad english..
            Greetings from PH.
              skizzopatrick
              Hi Guys,
              After reading the suggestions and tried different ways I still cannot figure out how to solve this thedious problem.
              Here you can find the "Ruby console" output.
              Closing UI
              Starting Export
              Error: #<NameError: uninitialized constant LumenRT2015::VueExportGUI::Main>
              e:/program files/e-on software/lumenrt 2015/lumenrt/export/skp/ruby/lumenrt_ui.rbs:477:in showUI' e:/program files/e-on software/lumenrt 2015/lumenrt/export/skp/ruby/lumenrt_menu.rbs:139:in lumenRT_exportModel'
              e:/program files/e-on software/lumenrt 2015/lumenrt/export/skp/ruby/lumenrt_menu.rbs:535:in block in <module:LumenRT2015>' SketchUp:1:in call'
              All the best.
              Patrick
              • 2 / 2
