    Mac Ruby Console is multi-line
    9 Posts 3 Posters 1.2k Views 3 Watching
      driven
      I've only just realised that Ruby Console on mac is multi-line, if you use alt/return at end of line, it moves up a line.
      add as many as you need, normal Return for submit...
      I always copy/paste multiline, I just didn't know you can type it.
      Maybe everyone else knows this, but I've never seen it mentioned.
      john
        driven
        I decided to have another go at the NIB, now I know it's already multi-line.
        bottom grows  top scrolls
        minimized using handle
        or hud even...
        not quite a code editor, as navigation is by mouse, left/right keys.
        Tab or return send to SU.
        john
        in case any mac uses are interested...
        • Dan RathbunD Offline
          Dan Rathbun
          @driven said:
          ... in case any mac uses are interested...
          I would think they would be.
          Is there a way to turn on and off these "tweaks" with a Sketchup checked menu item (which is saved using Sketchup.write_default ?)
          Can the panes be sized vertically (vertical sizing cursor) by dragging the separator bar between them ?
          I'm not here much anymore.
            @driven said:
            [attachment=0:56deglr4]<!-- ia0 -->2012-01-21 01.22.20 pm.png<!-- ia0 -->[/attachment:56deglr4]
            How did you do that???
              driven
              the way I switch between them is to have a RubyPanel folder with 3 sub-folders RubyPanel, RubyPanel_Hud and RubyPanel_Mod inside the the NIB's folder, in each folder I have one RubyPanel.rb. I just move a copy out two levels and replace existing. It could be done with a ruby for next startup, or one of my applescripts prior to launch. I can'tchange the path in the NSWindow chain.
              I tried a split window, to get the second scroll, but at the time I couldn't workout connection back into the binary.
              I also tried replacing it with an 'osascript' editor [text highlighting], but hooking it up is a problem.
              All these bits, are just re-purposing the existing hardcoding. not adding new. That would need recompiling, I think, but will look more.
              One of the issues' that stop it being a proper editor is that Cocoa injects a 'field editor' that handles key presses. So Tab will jump to the next item, not Tab the line. http://developer.apple.com/library/mac/#documentation/Cocoa/Conceptual/TextEditing/Tasks/FieldEditor.html
              It's probably why there is a mac_only_use_NSwindow [or whatever] as that would call this 'field editor' if you wanted 'native' style tabbing in a webdialog.
              I think there's more tricks that can be pulled, but going through IB [Interface Builder] isn't straight forward.
              There's no code to look at, and option A may hide options B, C. however option F, pops option C back on the menu, if you look at the right time.....
              Another thing I have done that makes it very handy is set it to operate without the parent window... As long as SU is on, I can run it like a desktop widget, and float it beside or on top of my external editor.
              john
                driven
                Not easily....
                but now I know you only get one chance to grab the text options for the top 'SU reply' field, unless you add some text...
                hence the # SU returns => is fixed text, always at the top of the first reply.
                you can grab that [in IB] and change it's color, background or wording, not much else.
                Oh, and you need a colored background on that layer, not 'hidden'.
                There are Three layers of background on that field... and one wants to hide.
                john
                  driven
                  UGLY success... now to make it pretty
                  should be able to scroll both next..
                    driven
                    I cannot get the input pane to scroll... aaaahhhh, yet
                    one of each... split panes
                      driven
                      Hi all you avid followers...
                      For the record, I've been using the modified nib constantly for a over a week now and thought I'd make some comments.
                      The cursor is a little hard to spot in 'hud' mode as I can't change it from the normal text input 'black', but being able to see through to the model more than compensates.
                      It's hard always remembering to Alt/Return for newLine as Return is Submit.
                      I have it set to always stay on top, very handy when working with an external editor, but I'd rather be able to toggle that.
                      I discovered last night that it has a back/forward function, i.e. using the arrow keys you can go back 1..3 inputs, tweak and re-submit.
                      This makes a inputing instead of newLine error a bit less of an issue.
                      If there are any mac users interested in trying this out 'speak up' or is it t'ype up'.
                      I'm happy to PM my 'findings' for your perusal, but I won't be attaching NIB files to this post.
                      john
