    Looking for File Parcer
    5 Posts 4 Posters 1.7k Views 4 Watching
    • A
      a4chitect
      you mean a tool able to parse text data into geometry?
      • T
        todd burch
        Can you be more specific? Is this on Windows? Once this text is parsed, what do you want to do with it?
        • T
          todd burch
          Any scripting language with Regular Expression (RE) support comes to mind, (Perl, Ruby, Python, VB) unless the format is so predictable that parsing based on column offsets and/or data attributes doesn't warrant RE use. I've done several tasks for myself and others using Ruby to perform such a task. The last one was for a telephone company in Oklahoma, parsing out records for a reverse-phone number lookup directory. (sorted on phone number, not last name).
          Not sure what a .cdf is.
          If you want to send me a complete sample, I can quote it for you.
          • M
            mozzie
            For "quick and dirty" stuff, there's a number of old command line utilities ... free.
            I've used "gawk" with considerable success extracting data from various proprietary/COBOL datasets of 100,000s of lines. Its a really simple regular expression script language, well documented (O'Reilly or The AWK book http://www.gnu.org/software/gawk/manual/gawk.html), available for Windows (http://gnuwin32.sourceforge.net/packages/gawk.htm) Mac (http://gawk.darwinports.com/) etc.
            It reads a line of text, does the parsing, writes it out. Fast.
            If you have formatted printout type data then I've also had success with Monarch (but its expensive) http://www.datawatch.com/
            Good luck
            • AdamBA
              AdamB
              Sure you could use grep, sed etc but wait, what if we had a scripting language in Sketchup that had good file reading capability, powerful regular expression matching, and a binding to the Sketchup geometry API etc.
              I guess we can only hope. πŸ˜„
              Seriously, something like this works fine:
              IO.foreach("my_inputfile.ext") { |aline|
                      /^(\S*) ([^$]*)/.match(aline)
                      verb = $1
                      rest = $2
                      case verb
                      ....whatever you need to do here eg entities.add_face, entities.add_group etc
              This is my mickey mouse .obj importer I use for Sketchup:
              pos = []
              tex = []
              group = nil
              IO.foreach("/tmp/test.obj") { |aline|
                      verb = $1
                      rest = $2
                      case verb
                              when "s"
                                      # ignore smoothing group
                              when "v"
                                      # close current group
                                      if group
                                              pos = []
                                              tex = []
                                              group = nil
                                      / (\S*) (\S*) (\S*)/.match(rest)
                                      pos.push Geom;;Point3d.new($1.to_f,$2.to_f,$3.to_f)
                              when "f"
                                      if /(\S*)\/(\S*) (\S*)\/(\S*) (\S*)\/(\S*)/.match(rest)
                                              vertices = [pos[$1.to_i], pos[$3.to_i], pos[$5.to_i]]
                                      elsif /(\S*) (\S*) (\S*)/.match(rest)
                                              vertices = [pos[$1.to_i], pos[$2.to_i], pos[$3.to_i]]
                                      group.entities.add_face vertices
                              when "g"
                                      # open a new group
                                      /(\S*)/.match(rest)
                                      group = Sketchup.active_model.entities.add_group
                                      group.name = $1
                                      puts "group(#{$1})"
              Adam
