    Looking for File Parcer
    5 Posts 4 Posters 1.7k Views 4 Watching
      a4chitect
      you mean a tool able to parse text data into geometry?
        todd burch
        Can you be more specific? Is this on Windows? Once this text is parsed, what do you want to do with it?
          todd burch
          Any scripting language with Regular Expression (RE) support comes to mind, (Perl, Ruby, Python, VB) unless the format is so predictable that parsing based on column offsets and/or data attributes doesn't warrant RE use. I've done several tasks for myself and others using Ruby to perform such a task. The last one was for a telephone company in Oklahoma, parsing out records for a reverse-phone number lookup directory. (sorted on phone number, not last name).
          Not sure what a .cdf is.
          If you want to send me a complete sample, I can quote it for you.
            mozzie
            For "quick and dirty" stuff, there's a number of old command line utilities ... free.
            I've used "gawk" with considerable success extracting data from various proprietary/COBOL datasets of 100,000s of lines. Its a really simple regular expression script language, well documented (O'Reilly or The AWK book http://www.gnu.org/software/gawk/manual/gawk.html), available for Windows (http://gnuwin32.sourceforge.net/packages/gawk.htm) Mac (http://gawk.darwinports.com/) etc.
            It reads a line of text, does the parsing, writes it out. Fast.
            If you have formatted printout type data then I've also had success with Monarch (but its expensive) http://www.datawatch.com/
            Good luck
            • AdamBA Offline
              AdamB
              Sure you could use grep, sed etc but wait, what if we had a scripting language in Sketchup that had good file reading capability, powerful regular expression matching, and a binding to the Sketchup geometry API etc.
              I guess we can only hope. πŸ˜„
              Seriously, something like this works fine:
              IO.foreach("my_inputfile.ext") { |aline|
                      /^(\S*) ([^$]*)/.match(aline)
                      verb = $1
                      rest = $2
                      case verb
                      ....whatever you need to do here eg entities.add_face, entities.add_group etc
              This is my mickey mouse .obj importer I use for Sketchup:
              pos = []
              tex = []
              group = nil
              IO.foreach("/tmp/test.obj") { |aline|
                      verb = $1
                      rest = $2
                      case verb
                              when "s"
                                      # ignore smoothing group
                              when "v"
                                      # close current group
                                      if group
                                              pos = []
                                              tex = []
                                              group = nil
                                      / (\S*) (\S*) (\S*)/.match(rest)
                                      pos.push Geom;;Point3d.new($1.to_f,$2.to_f,$3.to_f)
                              when "f"
                                      if /(\S*)\/(\S*) (\S*)\/(\S*) (\S*)\/(\S*)/.match(rest)
                                              vertices = [pos[$1.to_i], pos[$3.to_i], pos[$5.to_i]]
                                      elsif /(\S*) (\S*) (\S*)/.match(rest)
                                              vertices = [pos[$1.to_i], pos[$2.to_i], pos[$3.to_i]]
                                      group.entities.add_face vertices
                              when "g"
                                      # open a new group
                                      /(\S*)/.match(rest)
                                      group = Sketchup.active_model.entities.add_group
                                      group.name = $1
                                      puts "group(#{$1})"
              Adam
