    Toolbar Icon checked_unchecked
    8 Posts 4 Posters 471 Views 4 Watching
    • G Offline
      Gultekinmg
      I have been trying to create toolbars auto closed when a tool item selected,
      If Toolbar is checked "off" at my array holds toolbar names.
      First item of a toolbar is used to mark this toolbar off/on at array.
      Thou.. My code works;..
      I have seen that validation process cause endless loop at my code and other validation procs used.
      Any better simple and safe code pleases?
      #localized instance vars.
      toolbar_name = @cmdstbname
      toolbar_look =  @cmdsubtoolbar
      toolbar_check =   @checkstbar
      check_no =      @checkindex
      cmd = UI;;Command.new("Fixpanel_"+toolbar_name) {
              if @txtoolbar_name_array[check_no][2] == "off"
                 @txtoolbar_name_array[check_no][2]= "on"
                 Sketchup.status_text = " (#{toolbar_name}) Panel Pinned no auto-
      close when a tool selected."
              else
                 @txtoolbar_name_array[check_no][2]= "off"
                 Sketchup.status_text = "(#{toolbar_name})  Panel tempered to auto-
      close."
      cmd.small_icon = "../images/ruby_favorite_SM.png"
      cmd.large_icon = "../images/ruby_favorite_LG.png"
      cmd.tooltip =  " Pin (#{toolbar_name}) Panel"
      cmd.status_bar_text =  " Pin (#{toolbar_name}) Panel"
      cmd.menu_text = " Pin (#{toolbar_name}) Panel"
      cmd.set_validation_proc {
      p {check_no}
        if @txtoolbar_name_array[check_no][2]== "on"
              MF_CHECKED
        else
          MF_UNCHECKED
      @cmd = cmd  # add cmd.item to toolbar
      ##### or ####
      def check_validation_proc(check_no)
      p {check_no}
              return MF_CHECKED
        else
          return MF_UNCHECKED
      cmd.set_validation_proc { check_validation_proc(check_no) }
      Beware: Jim.Foltz ToolBar 2010 does same loop. if you inject - p "this is bug." - in 'toggleperspective.rb' you'll see this.
      it repeats till toolbar closed.
        Validation procs are evaluated extremly frequently - ensure they do as little as possible.
          Jim
          Do not use Custom Toolbars as an example for creating toolbars - it uses unconventional techniques that won't make sense outside of Custom Toolbars (i.e. @cmd = cmd)
          In your example, you have defined the validation proc twice. Also, calling "return" from a proc doesn't make sense - when the proc exits, the value MF_CHECKED is returned implicitly.
          • G Offline
            Gultekinmg
            Thx. jim. i did not use twice. but, sampled it here that your code also makes infinite loop as i have install at GSU8m2.
            I need help to over come this. But Thom say do not use it. no solution for this?
            I have been testing my "Clean DeskTOP.rb" plugin to simulate menus on toolbar build on Jim Foltz Toolbar plugin. very close to post here. but i have no idea about copyrights that i could develop on his plugin. May i?
            sample. Clean DeskTOP.
            • Dan RathbunD Offline
              Dan Rathbun
              OK, I viewed this topic (per request,) and I do not have anything more to add to what Thomas and Jim have said.
              I'm not here much anymore.
              • G Offline
                Gultekinmg
                Ok. I am closing this thread with following conclusion.
                As far as i understand after examining all codes on toolbar and menu validation,"MF_" validation cause implicite loop at menu and toolbar handling to lower SU GUI-process.
                Since, most of SU-Toolbars use that validation procs they cost process time while they are open at your desktop.
                it might be why SU-menus autoclose. Since, we can't handle SU custom toolbars, we dont see how they are flouding on screen.
                I wonder why they use "MF_" validation at Toolbars, if it is Menu associated.
                That could be a reason for me to develop "Clean DESKTOP" plugin to organize Toolbars as "PS" utilizes.
                  Jim
                  I do not think there is an infinite loop - the repeating output is because the validation proc is being called by SketchUp very frequently.
                  Sure. I like the idea of disappearing toolbars.
                  • G Offline
                    Gultekinmg
                    frequently as much they MF_check, MF_unchek toolbar items. As long as CustomToolbars are open i guess they are repeading output.
                    Mercy, Jim. I'll post free for noel. I hope you customize it as you like it. All yours.
                    I'll drop item.cmd validation from code. sry that.😞
