    How to spin a barn part 2
    3 Posts 2 Posters 276 Views 2 Watching
      tspco
      Thanks to SD Mitch, I have a way to spin a barn better. The spin view plugin works great and can be recorded with Chris Fullmer's camera recorder. But the spin object plugin does not work as well. The resulting images are all the same, therefore no spin. Sorry about the non smooth replay of this, I set the spin view plugin up for 3 degrees per step, 0.1 second delay.
      [flash=480,360:wo7lesx9]http://www.youtube.com/v/jJixEJ0hbuA[/flash:wo7lesx9]
      By the way is there a way for the powers that be on this forum, could come up with a better way to post flash videos?
      like copy the embed code from you tube and drop it here with no editing? just curious.
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
        Roger
        You build it in the path of a tornado.
        http://www.azcreative.com
          tspco
          I could, but probably not. A tornado would be hard to make in SketchUP. That said, someone here will try to make a tornado.
