    Prevent deleting "marked" cpoints/guides ? How?
    2 Posts 2 Posters 274 Views 2 Watching
    • dereiD
      derei
      I often use cpoints and guide lines in my components as references, grip points, rotation axes and so on... so I would like to prevent them to be deleted by accident.
      Some time ago, I tried to make a tool that will delete the guides (cpoints, clines) on a selective manner.
      I tried to use observers and Attribute Dictionaries, but I failed... it seems that observers are too buggy and don't behave as expected. Or, maybe my judgement was wrong at the time.
      Currently, the problem is that guides are deleted from entire model, so a cpoint inside a component can't be preserved. My thought was to have a tool that will create cpoints/guides and add a dictionary entry to them, like a label. Then, a observer that will prevent deleting the "marked" guides.
      Any ideas/suggestions ?
      DESIGNER AND ARTIST DEREI.UK
      • thomthomT
        You can't prevent an object from being erased. You might be able to recreate it, if you manage to get any info on the erased entity (which is usually garbage by the time the oberser reports it), but you will very likely end up interfering with some other operation.
        Safer and easier might be to create a custom Erase Guides function that will omit your protected guides.
        It would be a useful tool, as I've also experience your frustration many time myself.
        You could use attributes on each entity, or you can use attributes on a layer. Both options would be useful.
